Just putting the finisheing touches on my '72 z coupe,
STEVEN
Post by STEVEN »
I put a new/used heater blower motor on and when i hook up the wires it runs, the switch is off inside and the key is not on, but when i try to hook it up it starts running, why??
Victor Hernandez
Re: Just putting the finisheing touches on my '72 z coupe,
Post by Victor Hernandez »
In past experience, blower motors feed from the ground their negative end, only the positive is switched. Sounds like its picking up always closed positive from another wire.
On Wed, May 30, 2012 at 3:11 PM, Steven
STEVEN
Re: Just putting the finishing touches on my '72 z coupe,
Post by STEVEN »
Thanks, got it working right, NOT that i need it living in sunny Arizona (ha!)Just want everything to work.
I had it pluged into the wrong wire, should of known the colors didn't match (daa!) r/y wire was hidden under windshield washer bag
Steve in Arizona.
TOM THIES
Post by TOM THIES »
sometimes it can be the simplest of things.. glad you got it working.
> Steven
> Thursday, May 31, 2012 9:35
> [anzhonda600owners] Re: Just
> Thanks, got it working right, NOT that i need it living in sunny Arizona > (ha!)Just want everything to work.
> should of known the colors didn't match (daa!) r/y wire was hidden under > windshield washer bag > Steve in Arizona.
> > In past
> only the positive is switched. Sounds like its picking up always > closed > > positive from another wire.
> > On Wed, May 30,
> running, why??
Victor Hernandez
Post some pictures or share a photobucket album with it :)
On Thu, May 31, 2012 at 1:20 PM, TOM THIES
> > Steven
> > AM
> > Thanks, got it working right, NOT that i need it living in sunny Arizona > > (ha!)Just want everything to work.
> > should of known the colors didn't match (daa!) r/y wire was hidden under > > windshield washer bag > > Steve in Arizona.
> > > In past
> > only the positive is switched. Sounds like its picking up always > > closed > > > positive from another wire.
> > > On Wed, May 30,
> > running, why??
