Carb
r savard
Carb
Post by r savard »
Howdy,  Does any other carb work nicely on the 600 motor?
Fred Schieszer
Re: Carb
Post by Fred Schieszer »
don't give up on the original carb, it's not that hard to clean up and tune. Make a new accel pump diaphragm from nitrile (cloth backed prevents extrusion) and clean and check needle valves. I always use an ultrasonic tank to get the gum and junk out!
fjs
Sent from my iPad
pommecoing
Re: Carb
Post by pommecoing »
Although you are right about the original carb, several persons actually did use other carbs on 600 sedans.
Have a look to this video : http://www.youtube.com/watch?v=gdT4wU1wdaE
> fjs
> Sent from my iPad
John Mills
Re: Carb
Post by John Mills »
I have used a CV harley carb,( late 80's) they adapt very easy, even still used the original filter box.
It looks right at home, just had to make a change to the cable bracket and made an adapter out of exhaust pipe to mount. I am now back to the original carb,,,,but just for originality ...the HD carb works better.
Re: Carb
I never heard of that, sounds interesting - �got any pictures?
r savard
Re: Carb
Post by r savard »
CV harley carb? What is "CV"?
> "jbmkwaj@..."
> Thursday, March 8, 2012 1:46 PM
> Re: [anzhonda600owners] Re: Carb
> From: pommecoing
> To: anzhonda600owners
> Sent: Thu, Mar 8, 2012 10:24 am
> Subject: [anzhonda600owners] Re: Carb
> > fjs
> > Sent from my iPad
blake neilson
Re: Carb
Post by blake neilson »
Some say CV stands for constant velocity, others say constant vacuum (across the main jet).  Constant velocity seems to make more sense to me.
r savard
"anzhonda600owners@yahoogroups.com"
Thursday, March 8, 2012 7:36 PM
> "jbmkwaj@..."
> From: pommecoing
> > fjs
> > Sent from my iPad
John Mills
Re: Carb
CV is constant velocity, same as your Honda stock carb. The Harley ( built by Keihen - just like the stock Honda carb ) carb looks more like the older style with the flat cover, but looks nice since they are painted black. These carbs are plentyful and all parts are still available, no I dont have any installed photos but I still have the set-up. No change to the throttle cable, but I did have to grind down the knob a bit on the choke cable to make it fit. This is a very easy retro fit and looks like a factory install when done.,  You can buy these for about $50.00
Re: Carb
Sounds like an the way to go.
Do you have a source, part number...
> jbmkwaj@...
> Thursday, March 08, 2012 7:58
> Honda stock carb. The Harley ( built by Keihen - just like the stock Honda > carb ) carb looks more like the older style with the flat cover, but > looks nice since they are painted black. These carbs are plentyful and all > parts are still available, no I dont have any installed photos but I still > have the set-up. No change to the throttle cable, but I did have to grind down > the knob a bit on the choke cable to make it fit. This is a very easy retro > fit and looks like a factory install when done.,  You can buy these for > about $50.00
> -----Original
> Message-----
> From: r savard
> anzhonda600owners
> Sent: Thu, Mar
> 8, 2012 5:36 pm
> Subject: Re: [anzhonda600owners] Re: Carb
> > jbmkwaj@...
> > " > jbmkwaj@...
> > Thursday, March 8,
> > 2012 1:46 PM
> > Re:
> > It looks right at home, just had to make a change to the cable bracket > > and made an adapter out of exhaust pipe to mount. I am now back to the > > original carb,,,,but just for originality ...the HD carb works > > better.
> > From: pommecoing
> > > pomier.cohen@...
> > anzhonda600owners > anzhonda600owners@yahoogroups.com
> > Although you are right about the original carb, several persons > > actually did use other carbs on 600 sedans.
> > , Fred Schieszer
> > carb, it's not that hard to clean up and tune. Make a new accel pump > > diaphragm from nitrile (cloth backed prevents extrusion) and clean and check > > needle valves. I always use an ultrasonic tank to get the gum and junk > > out!
> > > fjs
> > > Sent from my
> > iPad
John Mills
Re: Carb
Bill, check out e-bay, there are used for about 50 bucks and New for $129 or $150 I used the stock Honda cable bracket, but modified a bit, bolts right on and used about a two inch long ( if I remember right ) extention on the engine side. I considered making a kit and offering it for sale to 600 owners but just don't have to time right now.
