Good day all;
My name is Kenny and I live in Denver,CO. I have a 1972 Honda AZ600
coupe and the compression rings on the driver side piston are broke. I
was thinking of rebuilding the top end with the oversized pistons(1mm
bigger .15 taller). Has anyone had any experience with these? A quick
search has shown me there may be some crankshaft issues? If so does
any one know where I may purchase oem pistons?
Another note is that the slot for the upper cam chain slipper pin has
worn larger, is this critical and repairable? This has been my daily
driver for years and I am anxiuos to get her back on the road.
thank you for your time.
Kenny
Rebuilding top end.
jeffanson2005
Re: Rebuilding top end.
I've found some rare stuff at www.majestichonda.com. Dealer is in
Rhode Island, I think. They have found some parts I needed for my 79
Civic and 72 z600.
Good luck!
Jeff
Civic and 72 z600.
Good luck!
Jeff
Majestic Honda's 600 parts have been exhausted. You can't find much
more than oil filters from dealers any more.
dawn_and_darrian
All dealers list the parts, but when you try to buy them they'll let you know that the parts are unavailable.
> jeffanson2005
> Friday, November 24, 2006 7:56
> [anzhonda600owners] Re:
> Rebuilding top end.
> www.majestichonda. com
> . Dealer is
> in
> Civic and 72 z600.
> Good luck!
> Jeff
GERRY DEMARS
Kenny, I have an oversize piston kit if you need one. I also have a new camsaft. gerryd
> devobrew
> Friday, November 24, 2006 9:16
> [anzhonda600owners] Rebuilding
> top end.
> Good day all;
> Honda AZ600
> coupe and the compression rings on the driver side piston are > broke. I > was thinking of rebuilding the top end with the oversized > pistons(1mm > bigger .15 taller). Has anyone had any experience with these?
> A quick
> search has shown me there may be some crankshaft issues? If so > does > any one know where I may purchase oem pistons?
> Another note is
> thank you for your
> time.
> Kenny
Thanks Gerry;
Some questions; Have you used these types before? What was your
experience? How much are they? By chance do you have an over-sized
cylinder;it would save me finding a machinist.
thanks
Kenny
thanks
Kenny
