Sedan Trailer Hitch
Sedan Trailer Hitch
Post by feltonminicycle »
A while back someone was looking for info on making a trailer hitch. I found mine in my shed, C an you contact me again and I will send pictures.
z600miles@...
J Graf
Re: Sedan Trailer Hitch
Post by J Graf »
T'was me. I'l email off list.
- - - - - - - - - - - - - - - - - - - - John Graf
On Dec 17, 2013, at 2:57 AM, A while back someone was looking for info on making a trailer hitch. I found mine in my shed, C > an you contact me again and I will send pictures.
> z600miles@...
>  Miles
oral roberts
Post by oral roberts »
you have trailer hitch
> z600miles@...
>  Miles
J Graf
Post by J Graf »
No. No trailer hitch - - yet. I asked for, and received, some information from some group members who had made and installed a hitch on their sedan or coupe.
Tom Rapini
Post by Tom Rapini »
I got a 1940's Sears Allstate trailer from my 90 year old neighbor's garage.  I call it the "wacky wheel" trailer because it only has one swiveling wheel.  The "hitch" is actually two "hinge" points that are permanently attached to the left and right sides of the rear bumper.  So, if you can visualize it, the entire trailer swings with the vehicle body, its single wheel pivoting to accommodate turns.
Not sure this will help you guys.  It works well for my purposes, small and very light.  Picture is at www.evalbum.com/325
Tom
> J Graf
> Wednesday, December 18, 2013 8:31
> Re: [2cylinderhondas] Sedan
> Trailer Hitch
> No.
> No trailer hitch - - yet. I asked for, and received, some information from > some group members who had made and installed a hitch on their sedan or coupe.
> John Graf
> > you have trailer
> > hitch
Mikey
Post by Mikey »
Back in the 60's one my my high school teachers had that same "item" on his Dodge.
Tom Rapini
Tuesday, December 31, 2013 1:12 PM
[2cylinderhondas] Re: Sedan Trailer Hitch
Tom
> J Graf
> Trailer Hitch
> No.
> John Graf
> > you have trailer
> > hitch
mygto_1999
Post by mygto_1999 »
They appear a lot on a VW site I frequent, www.thesamba.com . You can go to their classifieds and simply do a search for allstate and you come up with this:
http://www.thesamba.com/vw/classifieds/ ... ton=Search
You can also narrow it down by state by choosing that on the right side.
Happy New Year!
Mike
bottom cop
Post by bottom cop »
A friend built one of these.  He found a pivoting wheel from a piece of farm machinery, built a mounting T-bar that went into his regular hitch reciever but gave him two pivot points at the rear of the vehicle and set it up to hinge and lock up in the air so the wheel would be off the ground when the trailer was not needed. It was made of light weight materials but could easily haul 500lbs.
Mike & Tami Speer To:
Wednesday, January 1, 2014 2:10 PM Subject:
RE: [2cylinderhondas] Re: Sedan Trailer Hitch
They appear a lot on a VW site I frequent, http://www.thesamba.com/ . You can go to their classifieds and simply do a search for allstate and you come up with this:
Happy New Year!
Mike
Charles Gould
Re: Can anyone help me source all of the following parts for my Z600
Post by Charles Gould »
Good morning, I would be extremely grateful if anyone could help me source each of the following parts for my Z600 Coupe engine rebuild. I would prefer NOS parts, but would certainly consider any good used or reproduction parts.
I would be happy to pay a a fair price or to trade parts or to return the favor if anyone wishes to sell or donate any parts to this cause. I have quite a few spare parts that I would be willing to trade for the parts that I require.
I appreciate any help or advice in sourcing these necessary parts.
Thank you in advance for any help that you can provide.
Perhaps someone has a complete gasket set which would include many of these parts?
Kind regards,
Charles
(1) dust seal /alt side cover/35x 47x6&&&&&...51216. 91216-568-003 (1) points shaft oil seal 20x30x5 &&&&&&&..51211. 91203-551-006 (1) tach drive oil seal 4.8x15x4&&&&&&&.&54008. 91256-623-000 (1) condenser&&(generic or)&.&&&.....&&&34422. 30104-551-004 (1) gasket, left side cover&&&&&&&&&&..50043. 11396-568-020 (1) gasket, right side cover&&&&&&&&&... 50044. 11398-551-000 (1) seal, l crankcase side cover (67x82x8)&..&&..51214. 91212-551-005 (1) seal, clutch drum (20x30x5)&..&.&&&.&&04044. 91208-259-000
(2) ring set, standard&&&&&&&&&&&&..51943. 13001-568-010 (---OR---at the least) (2) new or used top rings&&&&&&&&&&&..DNA ---may need o/s pistons and rings, pending cylinder/piston final inspection--- (1) diaphragm set, accelerator pump &&&&&.&&54494. 16021-567-004 (1) gasket set, carburetor &&&&&&&&&&&...54514. 16010-601-004 ---most internal carb O-rings could be found in MC parts--- (1) O-ring 2.4x42, intake manfold&.generic?...............33849. 91325-568-000 (1) O-ring, fuel valve solenoid&&&generic?....................NOT LISTED (1) spring, vacuum piston&&MC&. interchange? &&&NOT LISTED (1) brush assy&&&&&&&&&&&&&&& 50340. 31130-568-015 (1) brush holder gasket&&&&&&&&&&&&50341. 31139-568-000 (1) primary drive chain tensioner roller&&&&& 50072. 13453-568-060 (2) cam chain roller axle bushings&&&&&..&&50101. 14641-551-030 (1) cam cover collar, special sealing &&&&&& 52047. 12904-551-010
(1) friction disc&&&&&&&&&&&&&&..52795. 22200-568-000 ----OR---- (1) clutch and primary drive kit &&&&&&&&..54431. 22000-568-010 (which includes clutch spring, friction and pressure discs, primary drive dampers and all relevant gaskets and seals.) (1) pin, knock, 14x20&&&&&&&&&&&.& 51184. 90701-551-000 (1) pin, knock, 10x14&&&&&&&&&&&&..06933. 94301-10140 (2) wrist pin, standard &&&&&&&&&&..&. 50066. 13111-568-000 (4) circlip (same as MC)&&&&&&&&&..&.. 07490. 13115-283-000 (1) oil filter assy&&&&&&&&&&&&&&&&&..50126. 15461-551-315 (1) O-ring, oil filter bolt (same as m/c)&&&&&&&&& 52105. 91301-551-000 (1) gasket crank retainer holder (can fabricate)&&&&&&52958. 13416-551-303 (1) oil seal, retainer (32.5x48x8)&&&&&&&&&&&...51210. 91202-568-020 (1) oil seal, speedo drive gear (8x16x6)&&&&&&&&&52296. 91208-551-015 (1) O-ring, speedo drive (20.5 x 1.8)&&&&&&&&&&.51222. 91313-551-000 (1) gasket, reverse return spring seat (can fabricate)...........&..50324. 24691-551-020 (1) oil seal, rod gear shift (14x25x7)&&&&&&&&&&.51215. 91215-551-003 (1) oil seal, diff right (54x75x12)..&&&&&&&&&&&52000. 91201-551-005 (1) oil seal, diff left (54x75x12)&&&&&&&&&&&&.52001. 91206-551-005 (2) O-ring diff (24x2.0)&&&&&&&&&&&&&&&..51224. 91321-551-000
Matchbox Motors Microcar, Minicar & Motorcycle Museum c/o Charles Gould 163 Country Club Road Newton, Massachusetts 02459 XXX-XXX-XXXX XXX-XXX-XXXX www.Bubbledrome.com chasgould@...
scottwalters32
Post by scottwalters32 »
Hi Charles,
I'm working on a rebuild right now too.  Most of those parts can be found between these two places/organizations:
http://honda600shop.com/parts.php?Category=N+%26+Z+600
http://www.honda600carparts.com/engine.html
http://www.ebay.com/usr/eagle-hd
The first two have a lot of new reproductions including complete gasket sets, complete rubber seal sets, reproduction pistons with rings, etc, etc.  The 3rd has pulled used parts.  The parts I've ordered from him have all been within wear limits according to manufacturer specs.
Probably the best thing to do would be order what you can from there and then post an updated list here of parts you're still looking for.
Regards,
-scott
