sparkplug wires
sparkplug wires
hi well i'm waiting for my z600 to be delivered. i know that the insulation is off the spark plug wires. question: can the wires be replaced or the insulation restored and how? thanks wish me luck. dean
Click to become a designer and quit your boring job.
http://thirdpartyoffers.netzero.net/TGL ... VXVuRIp23/
John Brown
Re: sparkplug wires
Wire Splices, but you must ensure that you have at least an inch of
good wire extending from the coil body. Simply install your coil wire
end into this unit and tighten, do the same with your new plug wire.
An advantage of these is that you could use any available 7mm spark
plug wire or cap combination.
I have also seen the old wires dug out of the coil and new ones glued
in, but I can't vouch for the reliability or durability of that
method. I hope this helps.
John
insulation is off the spark plug wires. question: can the wires be> hi well i'm waiting for my z600 to be delivered. i know that the
An easy, clean, and waterproof install could be done by using NGK Plug> Click to become a designer and quit your boring job.
> Hi Dean,
John
The Coronado Speed Festival
If you have not gone, I have a Club Section right behind the grand stands.
All the Honda 600's that want to show up just need to contact me for free
pass to the lot, but you need a ticket.
www.fleetweeksandiego.org/coronadospeedfestival
Go to the website and see what is happening.
Re: sparkplug wires
Dean try here...http://autos.ph.groups.yahoo.com/group/ ... rowse/18d6
> deantds@...
> Friday, September 12, 2008 6:00
> [2cylinderhondas] sparkplug
> wires
> hi well i'm waiting for my z600 to be delivered. i know that > the insulation is off the spark plug wires. question: can the wires be > replaced or the insulation restored and how? thanks wish me luck.
> dean
> Click
> http://thirdpartyoffers.netzero.net/TGL ... VXVuRIp23/ > ------------------------------------ > Yahoo!
> Groups Links
> To
Re: [anzhonda600owners] The Coronado Speed Festival
http://www.fleetweeksandiego.org/corona ... rclub.html
visit the Car Club area of the Speed Fest site, join us for a really great
time.
time.
Kevin Lister
Re: sparkplug wires
I pulled the wires out of my original coil as they were unusable. I chipped a little bit of the epoxy away to pull the wires. It didn't take much. I found that in the coil is a lance that is specifically made to go into the wire. The lance appears to be a stainless steel needle. It's very durable.
I bought some new 7mm wire and cut them to length and then installed them in the coil. They fit real good and I made sure that the wires were pushed all the way in. I never even glued them. I just pushed them in there. I've been running with those wires for over two years. No problems with them at all.
kev
kev
--- On Fri, 9/12/08, John Brown wrote:
> From: John Brown Subject: [2cylinderhondas] Re: sparkplug wires
> Date: Friday, September 12, 2008, 8:49 PM
> know that the
> wires be
> luck. dean
> Hi Dean,
> using NGK Plug
> inch of
> your coil wire
> plug wire.
> 7mm spark
> ones glued
> of that
> John
almightydoan
Re: sparkplug wires
What do y'all say about using a Harley coil like this person did?
http://fatboyraceworks.com/gallery/v/N600/Coil/
-Martin
-Martin
> kev
> > From: John Brown
> > know that the
> > wires be
> > luck. dean
http://thirdpartyoffers.netzero.net/TGL ... NGgww9S3cf
O5O5I8lD7AVXVuRIp23/
> > Hi Dean,
> > using NGK Plug
> > inch of
> > your coil wire
> > plug wire.
> > 7mm spark
> > ones glued
> > of that
> > John
Re: sparkplug wires
Hi Martin,
The motorcycle coils will work. Accel has some and you can find some other coils if you look on JC Whitney's site. The advantage of using the Honda 600 coil will be that it fits with no additional work to mount it and the plug wiring will be the correct length and sheathed to protect it from the engine heat and chassis metal. But if you can't locate a Honda coil, you gotta do what you gotta do.
Check out WalletPop for the latest news and information, tips and calculators .
Looking for simple solutions to your real-life financial challenges?> What
> http://fatboyracewo rks.com/gallery/ v/N600/Coil/
> -Martin
Re: sparkplug wires
I would say "Sure if it is a 1974 XLH sportster that came with
CONTACT POINTS!" Stick with the Accel, make sure you ask for
the "Points Coil" they are way better than the H.D. stock coils. use
this page, go for 2 or 4 cyl with points. like early Goldwing/KZ 650/
CB 500, and for jap stuff not H.D.
I am sorry I am a little biased, sure you can use the H.D. if you want
(the plug wires they give you may not be long enough)just get Points
type and if ya use the H.D. coil you can put a sticker in the back
window of you'r Z that sez "HARLEY EQUIPED" all the harley guys will
love it!
go to Accel Motorcycle coil 140403,140404,140403S,140404S Coil
Application Chart: Import Motorcycles 1366 KB ACCEL Motorcycle
http://www.mr-gasket.com/pdf/Coil_Application.pdf
you want the "140403" coil
:::::::::::::::::::::Zay
love it!
--- In 2cylinderhondas@yahoogroups.com, goinhm@... wrote:
> Hi Martin,
find some
using the Honda
and the
from the
coil, you gotta
> good luck,
> _http://fatboyracewohttp://fatboyrachttp://fatbo_
> (http://fatboyraceworks.com/gallery/v/N600/Coil/)
> -Martin
> **************Looking for simple solutions to your real-life
financial
> challenges? Check out WalletPop for the latest news and
> calculators. (http://www.walletpop.com/?
NCID=emlcntuswall00000001)
almightydoan
Re: sparkplug wires
So I'm going with the OEM coil. Replacing the wires with 7mm ones. Now I'm looking at the
plug caps from NGK. Would it be a problem if they had resistors in them? If not, would the
ones with 5 ohms resistance be alright?
Thanks
Thanks
> love it!
> --- In 2cylinderhondas@yahoogroups.com, goinhm@ wrote:
> > Hi Martin,
> find some
> using the Honda
> and the
> from the
> coil, you gotta
> > good luck,
> > Dale
> > -Martin
> financial
