My N600 needs both of the swaybar to body bushings in the front as
well as the bushings by the wheels. I have found the two front
bushings at Mikes 600 but I'm having trouble finding the ones for the
struts? Any ideas?
Thanks,Trout
Finally Running
Re: Finally Running
Hello Trout!
I have a full set of the lower bushings you are looking for. They are reproductions. If you are interested I am asking $20.00 for the set,Cashiers Check, Money Order or cash. Shipping is included.
Thanks
Greg
Thanks
Greg
> troutvortex
> Sunday, January 05, 2003 12:11
> [2cylinderhondas] Finally
> Running
> front as
> front
> bushings at Mikes 600 but I'm having trouble finding the ones for > the > struts? Any ideas?
> Thanks,Trout
> To
> Your
> Yahoo! Terms of Service
Re: Finally Running
--- In 2cylinderhondas@yahoogroups.com, "pipeline"
They are reproductions. If you are interested I am asking $20.00 for> Hello Trout!
> Thanks
> Greg
> From: troutvortex
> Sent: Sunday, January 05, 2003 12:11 AM
> Subject: [2cylinderhondas] Finally Running
> struts? Any ideas?
> Thanks,Trout
> Who reproduces these,I thought of using polyurethane type inserts?
> riceburner006
> Yahoo! Groups Sponsor
> ADVERTISEMENT
Re: Finally Running
Hello Riceburner!
I have a connection that made the mold for me. The bushings are made of a rubber that is a lot like polyurethane, but not quite as hard. I can also get reproduction cooling fan bushings if any one is interested.
Greg
Greg
> riceburner006
> Sunday, January 05, 2003 3:03
> [2cylinderhondas] Re: Finally
> Running
> "pipeline" dwieberg01@e
> > Hello Trout!
> > I have a
> They are
> reproductions. If you are interested I am asking $20.00 for > the > set,Cashiers Check, Money Order or cash. Shipping is included.
> > Thanks
> > Greg
> > From: troutvortex
> > To: 2cylinderhondas@yahoogroups.com
> > My
> N600 needs both of the swaybar to body bushings in the front > as
> the two front
> for the
> > struts? Any
> ideas?
> > Thanks,Trout
> > Who
> riceburner006
> > Yahoo!
> Groups Sponsor
> ADVERTISEMENT
> to:
> the Yahoo! Terms of
> Service.
> To
> to:
> Your
Re: Finally Running
Hey Pipe, thanks for writing back.
I need all six? the two front as well as the 2 per
each wheel. There are two different ones apparently.
A set for early and a set for late chassis numbers.
Do you know which ones you have? Can you send
pictures? I guess there is a difference in the
tie-rod diameter?
Thanks, Trout
--- pipeline wrote:
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
tie-rod diameter?
Thanks, Trout
--- pipeline wrote:
Do you Yahoo!?> Hello Trout!
> Thanks
> Greg
> From: troutvortex To:
> in the front as
> the two front
> struts? Any ideas?
> Thanks,Trout
> ADVERTISEMENT
Re: Finally Running
Hello Trout!
I do have the big ugly front sway-bar bushings also as reproductions. All of my bushings are for the later "fatter" sway-bar. I am currently "test" running a full set of the bushings on my Sedan, they seem to be doing real good. I will have to check my inventory to see how many bushings I have available. I will have an accurate count later this evening.
Thanks!
Greg
"sixtyfivechevypickup"
Thanks!
Greg
> JASON
> BABER
> Monday, January 06, 2003 10:27
> Re: [2cylinderhondas] Finally
> Running
> I need all
> numbers.
> send
> tie-rod
> diameter?
> Thanks, Trout
> --- pipeline dwieberg01@...
> > Hello Trout!
> > I have a full
> If you are
> Thanks
> > Greg
> > From: troutvortex
> > My
> > in the front as
> found
> > the two front
> having trouble
> struts? Any ideas?
> Thanks,Trout
> ADVERTISEMENT
> to:
> the Yahoo!
> > Terms of Service.
> Do you
> Yahoo!?
> To
> to:
> Your
Re: Finally Running
Dude, I used sway bar bushings off a vw bug to replace my missing
strut bar bushings. I only had to drill out the vw bushing slightly,
then they fit perfect.
Re: Finally Running
My brother did the same thing with his Honda. They did work. I decided I wanted to go more original (not that the original bushings are attractive) with my Sedan, so I looked around and found a guy that could reproduce the originals for me.
Greg
Greg
> Colin
> Tuesday, January 07, 2003 2:57
> Running
> missing
> strut bar bushings. I only had to drill out the vw bushing > slightly, > then they fit perfect.
> > Hello Trout!
> > I do have
> > Thanks!
> > Greg
> > From: JASON BABER
> > Sent: Monday, January 06,
> 2003 10:27 AM
> > Subject: Re: [2cylinderhondas] Finally
> Running
> back.
> as the 2 per
> ones apparently.
> chassis numbers.
> Can you send
> in the
> > tie-rod diameter?
> Thanks, Trout
> > --- pipeline
> > > Hello
> Trout!
> > > I
> > > looking
> > > interested I
> > > Check, Money
> > > Thanks
> Greg
> > > From: troutvortex
> > > Sent:
> > > My N600 needs
> > > in the front as
> > > the two front
> trouble
> > struts? Any ideas?
> Thanks,Trout
> ADVERTISEMENT
> > > To unsubscribe
> > Your use of Yahoo! Groups is subject to the
> Yahoo!
> > > Terms of Service.
> > Do you
> Yahoo!?
> now.
> ADVERTISEMENT
> to:
> the Yahoo! Terms of
> Service.
> To
> to:
> Your
Re: Finally Running
Hello Trout!
I do have one set of the lower arm bushings available. I hope to have more of the front bushings within the next few weeks.
Thanks!
Greg
Thanks!
Greg
> pipeline
> Monday, January 06, 2003 4:30
> Running
> Hello Trout!
> sway-bar bushings also as reproductions. All of my bushings are for the later > "fatter" sway-bar. I am currently "test" running a full set of the > bushings on my Sedan, they seem to be doing real good. I will have to check my > inventory to see how many bushings I have available. I will have an accurate > count later this evening.
> Thanks!
> Greg
> > JASON
> > BABER
> > AM
> > Running
> > I need all
> > chassis numbers.
> > send
> > tie-rod
> > diameter?
> > Thanks, Trout
> > --- pipeline > dwieberg01@...
> > > Hello Trout!
> > > I have a full
> > set,Cashiers
> > included.
> > > Thanks
> > > Greg
> > > From: troutvortex
> > 05, 2003 12:11 AM
> > Running
> > > in the front as
> > > well
> > > the two front
> > > struts? Any
> > ideas?
> > > Thanks,Trout
> > > Yahoo!
> > Groups Sponsor
> > ADVERTISEMENT
> > to:
> > to the Yahoo!
> > > Terms of Service.
> > Do you
> > Yahoo!?
> > To
> > to:
> > Your
> To
> to:
> Your
