Re: CV Boot Kits
honda72z600
Re: CV Boot Kits
Post by honda72z600 »
Can I used a Coil and plug wires for Honda CBR 600 F2 on this motor or do i
have to find the original coil?
J.
timk11
Re: CV Boot Kits
Post by timk11 »
Bill how much are the Empi's and what do they normally fit? I still
have the exact replica inners for $6.00ea with grease & bands. The
outers are good fit but not exact, have sold lots of these on eBay
with no complaints, used a bunch myself too. $20.00 set of 4.
I've also been dismantling the outer CV's completely and fitting the
best parts I have to make good driveshafts. Many a time the balls are
pitted or distorted, the cages are worn out and other stuff too!
I made a press plate to dismantle crankshafts, pressed a bunch, I
will be posting the pics in Photos section asap.
--- In 2cylinderhondas@y..., "william colford" wrote:
> Kits for your front CV Joints. CV Boots, EMPI Outer 86-1026-K,
Inner
> 86-1025-K will do the job nicely.
> Sent: Friday, June 28, 2002 4:45 PM
> Subject: [2cylinderhondas] CV Boot Kits
> > I am looking for a set of CV joint cover Boot Kits
> > 2cylinderhondas-unsubscribe@y...
timk11
Coils
Post by timk11 »
You can generally use any 12v coil which has 2 leads, such as Harley,
Honda 4's with 2 coils, Yamaha 650 twin should work nicely also.
or do i
> J.
Re: Coils
Hello J.
Miles is correct in that there are other coils that will work, but if
you are not going to use your old coil, maybe you could send it to me. I
have rarely found a coil that was bad, normally it is either the leads to
the plugs or one of the other two leads (Power and distributor leads) All of
them can be replaced. Along with a cleanup and touch of paint, the look and
operate like new again.
honda72z600
Re: Coils
Can you replace the plug wires, it looks like a one peace ceramic coil.
J.
honda600js
Re: Coils
Post by honda600js »
I just wanted to jump in here and say that this is an
excellent photo essay (it's in the photos section)
thanks!!
Ian
--- william colford wrote:
> Yes J. there is a how to fix your coil on
> From: To: Sent: Sunday, June 30, 2002 9:41 AM
> Subject: Re: [2cylinderhondas] Coils
> > J.
".... An elegant weapon from a more civilized time..."
Do You Yahoo!?
Sign up for SBC Yahoo! Dial - First Month Free
http://sbc.yahoo.com
