Brake Hose Alert
timk11
Brake Hose Alert
Post by timk11 »
I went to order more of that neat-o keen-o clear braided Kuritech
Brake Fluid Resivoir Supply Hose I have been giving away with the
master cylinder rebuilds. I was told the stuff I was supplying was
Food-Grade only. If you have this stuff on your car look see if it
has turned cloudy. I put this stuff on my car back in September and
it has clouded up, it is still firm but seems to be sweating.
They gave me some other stuff as replacement but could not guaranty
it for brake fluid. Sorry for any inconvienience this may have
caused, but I recommend you removing the clear hose I supplied, don't
know yet what a good replacement is. DOT 5 users may be ok since it
is a silicone non corrosive.
isettakurt
Re: Brake Hose Alert
Post by isettakurt »
Miles-
did you ever come up with a suitable brake reservoir hose replacement?
While tearing down my master cylinder to find out why my front brakes
are sticking (bleed-back hole did appear to be plugged...) I noticed
that the two braided hoses going to the reservoir on my Coupe are
hard as a rock and should probably be replaced.
What's the word, o wise one?
Dave K.
> caused, but I recommend you removing the clear hose I supplied, >
don't
H600
Post by H600 »
i am not the wise one but the bad bad one lol. i use a heat gun too warm the plastic lines up for removing and installing reservoir lines much easyer this way.
> Dave Kornberg
> Wednesday, November 06, 2002 5:28
> [2cylinderhondas] Re: Brake Hose
> Alert
> Miles-
> my Coupe are
> What's
> Dave K.
> don't
> > is a silicone non
> corrosive.
> > Miles
> To unsubscribe from this
> group, send an email
> to:
> Your
> Yahoo! Terms of Service
Post by Steve »
Uh, no. But the hose on Dinky is still holding. It seemed as it was
sweating through the hose, but seems fine now. I was told that clear
braided hose is only Food Grade. Did you try ordering that hose from
Honda?
--- In 2cylinderhondas@y..., "Dave Kornberg" wrote:
> Miles-
replacement?
brakes
noticed
> Dave K.
was
it
and
guaranty
> don't
it
> > Miles
