Link:
http://sfbay.craigslist.org/nby/cto/XXX-XXX-XXXX.html Not mine, just saw it.
Bruce D.
Santa Clara, CA From:
Greg To:
Thursday, July 2, 2009 1:29:50 AM Subject:
[2cylinderhondas] Re: clutch plate & linings
Miles, N360 palte is 18 spline on a 20mm shaft - that must then be the same as the N600 is it? Greg
2cylinderhondas@ yahoogroups. com
, "Miles" wrote:
> What I do for clutches is 3 years ago I bought 2 new Honda OEM discs from Mike O. I used one and I still have the other one. I'm installing the remaining one in an engine I have been rebuilding for the past 5 years for a friend in Redondo Beach.
> The discs I used to get from Napa said Japan & N360 on them. They were cheap, my cost about $35ea, and they worked great.
> I had a machine shop make me a fixture for the pressure plates for surfacing. The pressure plate is pretty flexible and needs to be supported in the center during surfacing. The clutch drum on the other hand can just be surfaced along with the ears.
, "Greg" wrote:
> > Mark, I'm in WA. BGT must have moved to Dandenong as that's the only Whitepages listing. I've emailed them.
> > Bill, thanks for that tip on MGB linings.
, "Mark Kuran" wrote:
> > > Greg, what state are you in? BGT in Hawthorn, Victoria were able to one for me a few years back.
> > > Mark.
, "Greg" wrote:
> > > > It's out of an N360 and I'm in Australia but as I said, the plate is the same diameter as N600.
> > > > Hey Miles, what do you do for clutches?
