electrical
electrical
hi every body does any body know where can I find the for all the electricaldiagram for the wires on my honda 600 1972 i seen it here in the groop but can find it no more thx.
Re: electrical
Here's 36 messages reguarding wiring diagrams:
http://autos.groups.yahoo.com/group/2cy ... ndows-1252
John Ph. Graf
Sedan Window Sweep
Is there an after market replacement available for the sedan door
outside window sweep? It's that rubber seal between the bottom of the
crank down window and the outside of the car which keeps [most] of
the rain from running down alongside the window down into the door
interior. I need that piece on each side of my sedan. Also would like
the similar piece that goes on the inside of the doors, along the
bottom edge of the glass.
Lastly, has anyone made a replacement trim piece that finishes off
the transition from the sedan door panel to that interior sweep
mentioned above? If you've made something passable to replace that
hard to find trim piece that's missing or broken on so many cars, I'd
like to know what you did and/or how you did it. I need to replace
both sides which are missing from my sedan. Or email me off list.
Thanks. John
Thanks. John
Daniel Middleton
Re: Sedan Window Sweep
I just made the window outside sweeps from repro sweeps for a full size pymouth...I just trimmed it and remounted it like a chrysler...works great!!! and only $12.00 for a pair...it also came withe a chrome beading on the door edge...
Date: Sat, 25 Apr 2009 15:13:32 -0500
Subject: [2cylinderhondas] Sedan Window Sweep
Is there an after market replacement available for the sedan door outside window sweep? It's that rubber seal between the bottom of the crank down window and the outside of the car which keeps [most] of the rain from running down alongside the window down into the door interior. I need that piece on each side of my sedan. Also would like the similar piece that goes on the inside of the doors, along the bottom edge of the glass.
Lastly, has anyone made a replacement trim piece that finishes off the transition from the sedan door panel to that interior sweep mentioned above? If you've made something passable to replace that hard to find trim piece that's missing or broken on so many cars, I'd like to know what you did and/or how you did it. I need to replace both sides which are missing from my sedan. Or email me off list.
Thanks. John
Rediscover Hotmail�: Get quick friend updates right in your inbox.
Check it out.
Thanks. John
Check it out.
roger white
Can we have details on your retrofit for window seals? I'm sure several of us have missing seals. Can you tell us where you got the Plymouth seal? What about the different mounting procedure? Thanks!
John Ph. Graf To:
Saturday, April 25, 2009 3:13:32 PM Subject:
Thanks. John
John Ph. Graf To:
Thanks. John
