hi this is dean i used the NGK end caps. i had no problem with resistors in them. i don't know about the others but i bought the ones with bent caps and they worked fine for me.
Are you a natural healer? Refine your skills at a Massage Therapy School.
http://thirdpartyoffers.netzero.net/TGL ... zm7Hp9mTF/
sparkplug wires
almightydoan
Re: sparkplug wires
Hi Dean,
Thanks for the reply. My wires just came in today. What type glue did you use or should be
used to glue the wires to the coil.
Martin
Martin
http://thirdpartyoffers.netzero.net/TGL ... 7YDCuXP3P4
WkFemfI9pzm7Hp9mTF/
Re: sparkplug wires
hi martin, i used a 5 minute epoxy. being carefull to keep from getting any on the ends. i put it around the wire then insert it to the coil. this may not be the best way or the best product but it has worked well for me. try to test for continuty befor the epoxy sets if you can. good luck dean
Hi Dean,
be
Martin
Learn about VA loan programs and benefits. Click now.
http://thirdpartyoffers.netzero.net/TGL ... zQWwgN5wj/
Hi Dean,
be
Martin
