Hello all.
I am rebuilding my N600 ‘late’ carb…
While checking all the passages I found a ‘blockage’ in the accelerator pump fuel passage in the float bowl – see attached photo.
It appears to be intentional since it is square in shape. Fuel does get by the edges of the block – so it appears it was installed as a flow restrictor.
Anyone else find this same feature in their carb?
Thanks.
Greg Prentice
Toromont Power Systems
XXX-XXX-XXXX
XXX-XXX-XXXX.
