Re: [2cylinderhondas] Parts or Repair
Just my observation.
I had one of these before; the damage was quite a bit more than what you see in the pictures.  What you don't see is the subframe connection points, the strut that is bent and the knuckle that cut off the registration point of the strut.  (note the way the right front wheel is turned different than the left)  The rack is also toast.  This is a side hit with what looks like the vehicle was moving and with all the side force pushing the wheel and subframe against the engine case, well I would be surprised if there isn't a crack in the case.
The picture showing the front view is very telling, almost 5 inches moved toward the inside of the engine bay.
A very costly repair, the one I had was repaired because the engine ran, the brakes worked and all the interior was in very good condition.
I had it placed on a frame machine and replaced the left front body, fender and bumper, all the other parts were repaired.
But this does not look like the brakes work, the engine does not run and the interior is shot.
Unless the glass, bumpers and all the bolts are worth the price I would pass.
