Re: master cylinder rebuild kit?
mterrens
Post by mterrens »
http://www.honda600carparts.com/brakes.html
I used a bunch of brake parts from Bruce (including a fresh resleeved MC) to get my Coupe back on the road recently worked out fine.
Steve www.honda600coupe.com
P. D. Kelly
Post by P. D. Kelly »
Thanks a lot Steve, I'll give him a try.
Kelly
> Steven Michelsen
> Friday, June 28, 2013 8:36 PM
> RE: [anzhonda600owners] Re: master cylinder rebuild kit?
> Steve
> http://www.honda600coupe.com/
> anzhonda600owners@yahoogroups.com [mailto:anzhonda600owners@yahoogroups.com] > On Behalf Of > P. D. Kelly > Sent:
> Friday, June 28, 2013 8:16 PM
> Re: [anzhonda600owners] Re: Tires / Rims
> Hi
> Can anyone tell me where to get a rebuild kit for a master Brake cylinder for a Honda 600?
> Thanks for any help.
> Paul Kelly
> > Chad > spannchad@...
> > " > anzhonda600owners@yahoogroups.com
> > Thursday, June 27, 2013 6:22 AM
> > RE: [anzhonda600owners] Re: Tires / Rims
> > How many do you need? I have some.
> > John E
> > 6/27/2013 2:22 AM
> > Does anyone know where you can find any 10 inch rims for a Honda 600 Sadan > > --- In > > mailto:anzhonda600owners%40yahoogroups.com > > , notrace07@... wrote:
> > > I would just put new tires back on. Coker has them in stock and will ship them to you door step and then you will most Likely never need to worry about that part again. I had to put a tube in one of my new tires cause it would not seal properly.
> > > Kurt
> > > On Jun 13, 2013, at 12:29 PM, Robert James > rjamesblues@...
> > > wrote:
> > > > Ok, always learning something new, well maybe....
> > > > Tire shop took tires off but informed me ahead of time, that because the tires were over 10 years old, that they, and most of the 'big' tire shops would not remount them. As I needed the tires off to take rims to get powder coated, I went ahead and had it done.
> > > > To my surprise (but maybe I shouldn't have been), all 4 tires had inner tubes. The tires are michelin 145 SR10 ZX. The tire does not have "tubeless" on it anywhere, so are these tires suppose to have inner tubes? Or, are the tubes used to deal with a broken bead (looks like 2 tires have mangled bead due to who know what and when)?
> > > > On Thu, Jun 13, 2013 at 6:45 AM, Robert James > rjamesblues@...
> > > wrote:
> > > >> Well, I might be going over the dam! Heading over to America's Tires and hope for the best. They sell (and I assume mount) trailer tires.
> > > >> Bob
> > > >> On Thu, Jun 13, 2013 at 4:08 AM, richmccolman > richmccolman@...
> > > wrote:
> > > >>> It's water over the dam now, but I'd recommend checking out a smaller, non-chain tire outfit next time around. That's the sort of place I went to after I'd ordered my new tires online and needed them mounted and balanced. The outfit charged me a total of $20 to mount -- and balance -- all four tires, and I hadn't even bought the tires through them! (I even offered to pay them more to make it worth their while since I hadn't bought the tires from > > them, but they refused any more money.) Also, there was no problem with the size of the tires and wheels -- they dealt with them just fine.
> > > >>> If you go to a place that deals with all sorts of tires, including boat and utility trailers and lawn tractors, they should have all the equipment needed to handle your Honda 600 wheels. The chain places are often set up to deal with run-of-the-mill car and truck tires only.
> > > >>> Richard
> > > >>> --- In
> > , T W S wrote:
> > > >>> > i went to Walmart but they couldnt do
> > it because the rims were to small so i went to Tires Plus-they didnt give me a clear estimate and i ended up having to pay $104. That didnt put the tires on the car. They even charged for the weights they put on. If the tires wouldnt have been so hard to come by that serrvice manager would have had them where the sun dont shine.
> > > >>> > From: bobs600honda
> > > >>> > To:
> > > >>> > Sent: Wednesday, June 12, 2013 10:46 AM
> > > >>> > Subject: [anzhonda600owners] Tires / Rims
> > Any advice on removing tires from rims?
> > > >>> > Can any tire shop handle this?
> > > >>> > Thanks for any info.
> > > >>> > Bob
J Graf
Trailer hitch
Post by J Graf »
I posted this on the [2cylinderhondas] board a couple of days ago and got two great responses. I'm posting it here as well, in hopes that a different audience might respond with more good ideas. Thanks.
I once had, but lost track of, information about a trailer hitch installation someone had created for their 600. Is there anyone who has modded their sedan by adding a hitch? If so, are you willing to take pictures or otherwise explain how you did it? I'd like to build a small utility trailer that I can pull around town just for grins and giggles, but no real hauling. Please email me direct at
jgraf@...
. Thanks. John
- - - - - - - - - - 1970 N600 Red 1970 N600 Yellow 1972 N600 Yellow
Mark P Hatten
Re: Trailer hitch
Post by Mark P Hatten »
I'd like to know as well, I'd like to install a hitch as well. I didn't see the great responses on 2cylinderhonda yet, they have not come thru yet I guess
Mark
www.mphspecialties.com
To: anzhonda600owners@yahoogroups.com From: jgraf@...
Date: Sun, 15 Sep 2013 11:36:20 -0500 Subject: [anzhonda600owners] Trailer hitch
jgraf@...
. Thanks. John - - - - - - - - - - 1970 N600 Red 1970 N600 Yellow 1972 N600 Yellow
J Graf
Re: Trailer hitch
Post by J Graf »
Mark,
I asked for, and got, the responses direct. One response from Bill was for a method to tow my Honda behind some other vehicle. This is what Miles sent me about installing a hitch under my sedan, along with two photos:
I had a trailer hitch for my sedan. It is super easy to build. Your spare tire will be lots lower.
Basicly it is shapd like a T where the top of the T bolts through the rear chassis tube. And somewhere along the hitch tube a vertical tab gets welded on and one hole drilled through your bumper with say a 1/2" bolt.  With my 600 sedan hitch I was able to tow my BMW 600 (Isetta Limo)
I built a similar hitch for my 1993 Geo Metro.
Photo trktrlr shows rear of my sedan truck with tire hanger missing. That's the rear support tube about 12" back.
DSCF7245 is a coupe but shows extravagant over engineered hitch.
- - - - - - - - - - - - - - - - - - - - John Graf On Sep 15, 2013, at 7:31 PM, Mark P Hatten wrote:
> I'd like to know as well, I'd like to install a hitch as well. I didn't see the great responses on > 2cylinderhonda yet, they have not come thru yet I guess
Note: 4 image(s) originally linked in this post are no longer available (cid:9E071726-843A-4350-96F8-11EDE0104D38, cid:0AD65743-B276-4E61-A63F-99AA180781F2, cid:A261C404-D0AB-472E-BC80-26FD36FBC951 +1 more).
Chad
Re: Trailer hitch
Post by Chad »
Hi. I have a coupe with a trailer hitch. I didn't put it in but I can take pics if its helpful.
Mark P Hatten Sent:
9/15/2013 7:46 PM To:
Honda  600 group Subject:
RE: [anzhonda600owners] Trailer hitch
Mark www.mphspecialties.com
jgraf@...
. Thanks. John
J Graf
Re: Trailer hitch
Post by J Graf »
That would be great. I have a good idea of how I might do it, based on what Miles said, but there appear to be a few others in this group who are interested as well. It can't hurt to have extra data.
tdthies1
Re: Trailer hitch
Post by tdthies1 »
There is a yellow honda on ebay now that has a trailer and car with hitch.  U might try to contact him.
Sent from Samsung tablet
jgraf@...
J Graf
Re: Trailer hitch
Post by J Graf »
Thanks. Did that Friday. He said that he may be able to take pictures or video on the weekend (just past) and would send them to me. I'll post what I learn from him.
