Broken Bolt
baldwin_elias
Broken Bolt
Ok, so I broke off the bolt on the front of the engine, the one that the ground strap bolts to. Its broken off down in there, so I filled the hole with penetrating oil. Anybody have any experience with left-hand drill bits? Any advice?
Re: Broken Bolt
I've had great luck with them.
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
Re: Broken Bolt
It depends on how the bolt broke off. If it was cross threaded and forced in tight all the way or if it had corroded in and broke trying to remove it the left hand drill wont work. But if it was installed and had threaded in easily and was just over torqued until the head popped off, the left hand drill may work. Good Luck either way.
baldwin_elias To:
Mon, September 3, 2012 7:21:25 AM Subject:
[anzhonda600owners] Broken Bolt
baldwin_elias To:
