Re: [2cylinderhondas] Hawaiian Engine for sale
Steve, correct, the engine will fit in the Coupe chassis but t he early (or Hawaiian) type engine used an Angle Port Head (necessary to gain that additional power) that used the Y silencer and had the split header assembly which required the battery tray on the Coupe to be removed from the engine compartment.  The last one I modified had the battery moved to the area behind the rear seat.  The Coupe is about 3 inches narrower than the Sedan which gives little room for the exhaust system intended for that configuration.
But, you're right, the engine could be mounted in either car.
As far as the Tach goes; if the cam is a true early engine cam then there would have to be a hole for the tach drive and an additional hole with 6mm 1.0 threads machined to accommodate the bolt needed to hold the Tach drive in place.
Or a Tach drive cam could be reground giving it the early cam specs.  However then the area removed off the back end of the cam lobes will need something like lash caps to put the material removed, back on the end of the valve stem.  It all goes back to the saying "you can do almost anything if you throw enough money at it".
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > Steven Michelsen > Sent:
> Saturday, September 10, 2011
> 5:49 PM
> Elliott, for the record, if you do not know, the
> N600 is a sedan, and the Z600 is a coupe.
> The N has a trunk and the Z is a hatchback.
> The drivetrain on both are almost
> identical.
> The N has no tach, the Coupe does.
> Mike's "Hawaiian style" engine could go into either a Coupe or a sedan, > but as it's a sedan engine - no tach.  If one wanted to use it in a > Coupe, he could theoretically set it up with the parts to use it's > tach, I'll guess.
> Here is the coupe:
> http://www.honda600coupe.com/Honda_600_ ... Honda.html
> Here is the sedan:
> Steve
> > Elliot
> > Friday, September 09, 2011 6:53
> > AM
> > Engine for sale
> > Hi,
> > How much are you asking? also, do you know what the difference between > > a n600 vs a z600 is?
> > Thanks,
> > Elliot
> > On Sep 8, 2011, at 10:46 PM,
> > tmoc1990@...
> > > I have a N600 hawaiian style engine for sale with complete exhaust > > > system front to back include, less than 7800 miles, runs great, shifts > > > fine, no issues, tach drive camshaft, fully synro transmission, starter > > > included, mobil one oil only. Located in Statesville NC,
