Parts Supplier Needed
bitsurfer001
Post by bitsurfer001 »
Just bought a 72 z600 and am looking for a good part supply house.
I live in Berkeley, Ca.
Any suggestions?
Need a carb rebuild kit first...accelerator pump diaphram.
Pete
brad fenn
Re: Parts Supplier Needed
Post by brad fenn »
Check E-BAY  "Midwest Wholesale"  they specialize in 600 parts
bitsurfer001 To:
Sun, July 17, 2011 11:05:46 PM Subject:
[anzhonda600owners] Parts Supplier Needed
Any suggestions?
Thanks, Pete
johnny.siu
Post by johnny.siu »
hi Pete,
i have a z600, i live in san francisco and i have an extra carb rebuild kit for you. contact me here if you are interested. johnnysiu@...
cheers,
-j
> Any suggestions?
> Pete
bitsurfer001
Johnny-
Shoot. I wish I had seen this earlier...I purchased one off of e-bay.
I am looking for a brake master cylinder rebuild kit. Any suggestions?
I suspect I will need wheel cylinder and caliper rebuild kits as well.
Where do you get your parts? Looking for a good supplier.
Thanks.
Pete
, "johnny.siu@..." wrote:
> hi Pete,
> cheers,
> -j
> > Any suggestions?
> > Thanks,
> > Pete
Pete;
White Post restorations at www.whitepost.com
restores the brake system, master cylinders, boosters, calipers, rear cylinders and the proportioning valve.
Or you can spend the same amount doing it yourself and no warrantee.
> bitsurfer001
> Wednesday, July 27, 2011 8:11
> [anzhonda600owners] Re: Parts Supplier Needed
> Johnny-
> Shoot. I wish I had seen this earlier...I purchased one off of > e-bay.
> suggestions?
> I suspect I will need wheel cylinder and caliper rebuild kits > as well.
> supplier.
> Thanks.
> Pete
> > hi Pete,
> i have a z600, i live in san francisco and i have an extra carb rebuild kit > for you. contact me here if you are interested. johnnysiu@...
> cheers,
> > -j
> > > Just bought a 72
> > > I live in
> Berkeley, Ca.
> > > Any suggestions?
> > > Need a carb rebuild
> > > Thanks,
> Pete
bitsurfer001
Bill-
Thanks for the info.
I can do the rebuilds myself and am looking for the rebuild kits. Looks like Whitepost provides rebuilding services.
I have found most of the kits online, but am haveing trouble finding a complete brake master rebuild kit with the check valves. I'm sure I will wheel cylinder kits and front caliper kits as well, but have not got there yet. I did buy a carb rebuild kit and got the motor up and running.
pete
, wrote:
> Pete;
> White Post restorations at www.whitepost.com restores the brake system,
> valve.
]On Behalf Of bitsurfer001
> Sent: Wednesday, July 27, 2011 8:11 AM
> Subject: [anzhonda600owners] Re: Parts Supplier Needed
> Johnny-
> Thanks.
> Pete
, "johnny.siu@"
> > hi Pete,
> > cheers,
> > -j
> > > Any suggestions?
> > > Thanks,
> > > Pete
Hi Pete;
Yep, I am the same way.  Got to do it myself to get it right.  To resleeve a master cylinder in brass your looking at around $120.00 or more depending on the condition of the cylinder.  Then there is the seals to purchase and if the pistons are still usable there will be refurbishing costs to get them right.  And, if the check valves are correct (one has larger holes in it than the other) for front and rear.  If wrong they will raise heck with your brakes. The Calipers will not need resleeveing, but the pistons may need to be chrome plated to make them smooth again.  Many are pitted.  The rear cylinders are always in need of resleeving along with seals if the pistons are still good.  Check the area where the seal sits on the piston, many are corroded and will leak from there if not sealing properly.  Honda had them plated and the DOT3 brake fluid just destroys them.  If the pistons are to far gone, I found that getting a cup and spring like was used on the old GM wheel cylinders does the trick.  Just sleeve the cylinders in brass, pickup two cups and a spring the correct size and cut the pistons down.  Fit together and they work like a champ.  Some will say stainless steel sleeving is better, but it can crack the casting when pressed into place.
And to make them last for a long time, I use DOT-5.  Much more costly but keeps them running strong for years.
> bitsurfer001
> Thursday, July 28, 2011 5:11 PM
> Bill-
> looking for the rebuild kits. Looks like Whitepost provides rebuilding > services.
> I have found most of the kits online, but am haveing trouble > finding a complete brake master rebuild kit with the check valves. I'm sure I > will wheel cylinder kits and front caliper kits as well, but have not got > there yet. I did buy a carb rebuild kit and got the motor up and > running.
> pete
> > Pete;
> > White Post
> restorations at www.whitepost.com restores the brake system, > > master > cylinders, boosters, calipers, rear cylinders and the proportioning
> valve.
> no warrantee.
> ]On
> > Johnny-
> a good supplier.
> > Thanks.
> > Pete
> "johnny.siu@"
> > > hi
> Pete,
> > > i have a z600, i live in san francisco and i have an extra > carb rebuild > > kit for you. contact me here if you are interested.
> johnnysiu@
> > > cheers,
> > > -j
> In
> > > > Just
> > > > Any suggestions?
> > Thanks,
> > > > Pete
Kevin Lister
Post by Kevin Lister »
Bill,
Do you trust the folks at White Post to sleeve the master cylinders in brass?
kev
Thu, 7/28/11, billmyong@...
Subject: RE: [anzhonda600owners] Re: Parts Supplier Needed
Date: Thursday, July 28, 2011, 12:43 AM
Pete;
www.whitepost.com
> anzhonda600owners@yahoogroups.com [mailto:anzhonda600owners@yahoogroups.com] > On Behalf Of > bitsurfer001 > Sent:
> Johnny-
> Thanks.
> Pete
> > hi Pete,
> > cheers,
> > -j
> > > Any suggestions?
> > > Thanks,
> > > Pete
Hi Kev;
This is from their site, and they do say they will brass sleeve your cylinders.  Brass sleeving is a normal service to bringing back warn aluminum brake cylinders.  Using DOT5 brake fluid keeps your brake system running for a long time.  Yes there is maintenance, but the amount of maintenance using DOT5 compared to DOT3 is far less.
  The alternative is to change out your DOT3 fluid every other year or less.  I change out DOT5 about every 5 to 6 years.  Yes there have been cylinders that had to be rebuilt, but the inside of the cylinder on a vehicle using DOT5 is just like the day it was put together.   The only issue I have had is corrosion on the pistons under the seals where the fluid was changed over to DOT5 with out doing a complete rebuild.  There was some DOT3 left under the seal that caused the piston seal area to corrode and fail.
Attention to detail is the key, working with used parts can be costly, that is why using a resource like White Post Restorations is a good idea.
www.whitepost.com
The ULTIMATE
Solution to Your Brake Cylinder Problems.
White Post Restorations has a unique brake cylinder sleeving and rebuilding service, the ultimate solution to your brake cylinder problems.
Click here for our Brake Service Request Form
Our rebuilt cylinders are better than new, they will never rust, pit or corrode, because we install brass sleeves.
We disassemble the cylinders, glassbead clean, bore oversize, press in the brass sleeve and size them to original specifications. We rebuild your cylinder with all necessary new parts and apply an original finish on the outside.
We rebuild vacuum boosters for all cars and trucks.
We also reline brake shoes and disc brake pads.
All work is guaranteed with a written Lifetime Warranty.
Quick Service - Same Day & Overnight. (Normally 2 to 3 Days.)
When you receive your rebuilt brake cylinders, they're ready to bolt on your car, and you'll never have to touch them again!
> Kevin
> Lister
> Tuesday, August 02, 2011 7:58 PM
> Bill,
> Do you trust the folks at White Post to sleeve the master cylinders > in brass?
> kev
> --- On
> > billmyong@...
> > RE: [anzhonda600owners] Re: Parts Supplier Needed > > To:
> > 12:43 AM
> > Pete;
> > www.whitepost.com
> > cylinders, boosters, calipers, rear cylinders and the proportioning > > valve.
> > > -----Original
> > > Message-----
> > > [mailto:anzhonda600owners@yahoogroups.com] > > > On Behalf Of
> > > bitsurfer001
> > > Sent:
> > > AM
> > > Needed
> > > Johnny-
> > > one off of e-bay.
> > > Thanks.
> > > Pete
> > > > hi
> > > Pete,
> > > > i have a z600, i live in san francisco and i have an > > > extra carb rebuild kit for you. contact me here if you are > > > interested. johnnysiu@...
> > > > cheers,
> > > > -j
> > > > --- In
> > > > > Just
> > > bought a 72 z600 and am looking for a good part supply > > > house.
> > > > > Any
> > > suggestions?
> > > > > Thanks,
> > > Pete
Dave Rulez
Post by Dave Rulez »
I can tell you Sierra specialties did my master cylinder and it came out fantastic. He is also the guy Miles has used for years.
Dave
, Kevin Lister wrote:
> Bill,
> kev
> --- On Thu, 7/28/11, billmyong@... wrote:
> From: billmyong@...
> Pete;
> White Post restorations at www.whitepost.com restores the brake system, master cylinders, boosters, calipers, rear cylinders and the proportioning valve.
[mailto:
> Johnny-
> Thanks.
> Pete
, "johnny.siu@" wrote:
> > hi Pete,
> > cheers,
> > -j
> > > Any suggestions?
> > > Thanks,
> > > Pete
