Heater and Ventilation
Post by lyletrudell »
I removed the ventilation system from under the dash.
The foam was all falling apart so I used Home Depot sponge rubber weatherstripping with adhesive backing. Cut with scissors and stuck in place, worked out great.
The inlet box seal #5 and the ventilator case seal #34 is hard and cracked.
What should I use as a seal replacement?
I am sure the original seal is not available.
Thanks
