Ken, Linda and other restorers of the Honda 600;
Caution, the "O" ring is thinner tan the casual "O" ring supplied at the local hard ware store.
1 - It is thinner, to use one that is to thick will crack the base of the intake manifold when you tighten it down. Or two thin and it does not seal.
2 - It must be resilient to fuels, Viton is best but Nitrile or Buna-N will work just as well. Neoprene, Butyl or Natural Rubber will all fail. Which can cause a fuel leak and besides catching on fire, there is short term fuel mileage loss and erratic carburetor function.
3 - The person I was getting them from has retired so I have no idea of availability. Also, the invoice noted special shipping and that was back in 2005.
If you can't find them, let me know and I will get in touch with them on Tuesday.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > Kenneth Sievert > Sent:
> Thursday, May 27, 2010 3:10
> [2cylinderhondas] Manifold Gasket?
> I believe the manifold "gasket" is just an o-ring. I'm
> not sure about the size, so take the old one with. Most any hardware > store should have one.
> --- On
> Thu, 5/27/10, Linda Classon
> > Linda Classon
> > Date: Thursday, May 27,
> > 2010, 2:53 PM
> > Took my 71 Sedan to my local Honda dealer for a tune-up because it > > was > > running rough. The diagnosis is that it has a bad manifold > > gasket and > > there's gunk in the carburetor.
> > Does anyone have
> > or know where to get the manifold gasket? I don't > > care that it's > > authentic, just something that works. Also, does anyone > > do > > carburetor re-builds?
> > Thanks!
> > Linda in
> > CT
