Fan idler pulley bearings
Post by lyletrudell »
Started pulling parts off my engine so I can clean and repair them. When I removed the fan belt I noticed one of the idler pulley bearings was bad. The pulley has a blind pocket for the bearing. So putting it in is easy, getting it out......?
Anybody come up with a way to replce the bearing and shaft.
Drill a hole in the back and press out?
Then plug the hole?
paul tate
Re: Fan idler pulley bearings
Post by paul tate »
I have the same issue.  I was considering going to a mower supply store and buying a regual pulley of the same size and putting a bolt thru it.  Anyone see a problem with that?
Sun, 5/9/10, lyletrudell
> From: lyletrudell
> Subject: [anzhonda600owners] Fan idler pulley bearings
> Date: Sunday, May 9, 2010, 6:56 PM
> Then plug the hole?
> Lyle
Paul, that is another thought but finding one the right daimeter might be an issue. Somebody must have pulled the bearing before.
Might have to make a puller of some kind.....
Where are the Honda experts?
> --- On Sun, 5/9/10, lyletrudell wrote:
> From: lyletrudell
> Then plug the hole?
> Lyle
Lyle;
Go to the pictures of the Fan pulley bearing puller in the groups site.
I have used this set up for a number of years, works like a champ.
> lyletrudell
> Monday, May 10, 2010 4:30 PM
> [anzhonda600owners] Re:
> Paul, that is another thought but finding one the right daimeter might be > an issue. Somebody must have pulled the bearing before.
> Might have to make
> Lyle
> In
> paul tate wrote:
> > I have the same
> issue.�  I was considering going to a mower supply store and buying a > regual pulley of the same size and� putting a bolt thru it.�  Anyone > see a problem with that?
> lyletrudell
> and repair them. When I removed the fan belt I noticed one of the idler pulley > bearings was bad. The pulley has a blind pocket for the bearing. So putting it > in is easy, getting it out......?
> Then plug the hole?
> > Lyle
Thanks Bill, I knew you would have something!
Your Clever.
I wish you lived closer, I could bring the beer, talk mechanical stuff and press out my bearings.
Will have to make something, for 2 bearings!
, wrote:
> Lyle;
> ist
]On Behalf Of lyletrudell
> Sent: Monday, May 10, 2010 4:30 PM
> Subject: [anzhonda600owners] Re: Fan idler pulley bearings
> Lyle
, paul tate wrote:
> > I have the same issue.� I was considering going to a mower supply store
> and buying a regual pulley of the same size and� putting a bolt thru it.�
> > From: lyletrudell
> > Then plug the hole?
> > Lyle
