Re: FS: z600 coupe parts...bad timing chain??
Looking at your used cam chain ,  it appears to be stretched beyond the serviceable limits.  A new cam chain has about 3.25 inches of droop (below a horizontal line) and the chain in the picture appears to have about 5 inches of droop.  Then again,  the camera angle the lack of a good reference could be misleading me.
> located in socal westminster
> make me an
> offer
> -hood
> -front bumper
> -side markers
> -transmission top
> case
> -rear license holder (sand blasted and painted black)
> -valve cover
> CLEAN!
> -used head gasket
> -used timing
> chain
It's true, a rosary has the same number of beads as the Honda 600 cam chain has pins.   The difference between the two is that the used chain is closer to praying it won't break.   It is cheaper to replace a cam chain than 4 valves a cam and one of the end caps.
> goinhm@...
> Sunday, March 07, 2010 2:43
> [anzhonda600owners] FS: z600 coupe parts...bad timing
> chain??
> Looking at your
> used
> cam chain
> limits.  A new cam chain has about 3.25 inches of droop (below a > horizontal line) and the chain in the picture appears to have about 5 inches > of droop.  Then again,  the camera angle the lack of a good > reference could be misleading me.
> > make me an offer
> > -hood
> > -front
> > bumper
> > -side markers
> > -transmission top case
> > -valve cover CLEAN!
> > -used head
> > gasket
> > -used timing chain
Marshall
Post by Marshall »
I recently ran a camchain through my fingers & cursed !!!!! No wonder I'm having bad luck with my engine !!
]On Behalf Of goinhm@...
> Sent: Sunday, March 07, 2010 2:43 PM
> Subject: Re: [anzhonda600owners] FS: z600 coupe parts...bad timing chain??
> Looking at your used cam chain, it appears to be stretched beyond the
> be misleading me.
> make me an offer
> -hood
> -front bumper
> -side markers
> -valve cover CLEAN!
> -used head gasket
> -used timing chain
