Ignition/Charging circuit
trtlepnther21
Post by trtlepnther21 »
Looking for a little help from everyone.
It doesn't take much when looking under my 1970 Honda 600 Sedan's hood to figure out that someone has taken a few liberties when it comes to the electrical wiring. Missing the main fuse, wing nuts holding spliced wires together (I don't think they are OEM), a mess of electrical tape, and I can't figure out why. The car ran like this, and i can't remember what did and did not work while it WAS running.
I am rebuilding and want to get the electrical right. When I was attempting to start the vehicle for the first time in quite some time, it shorted one of two wires coming from the ac generator brush connected to the rotor assembly. WHY?
I have taken out wiring between the rectifier, battery, voltage regulator, and magnetic switch on the starter. I am going to replace every wire one at a time to ensure the load is being transfered properly and all connections are sound. I will snap a couple photos as it looks right now. ANY HELP IS APPRECIATED!!!
mterrens
Re: Ignition/Charging circuit
Post by mterrens »
Can't say why they shorted, but "stuff" does happen...
http://www.honda600coupe.com/fused_wiring_cleanup.html
Good luck!
> trtlepnther21
> Monday, January 25, 2010 1:21
> [anzhonda600owners]
> looking under my 1970 Honda 600 Sedan's hood to figure out that someone has > taken a few liberties when it comes to the electrical wiring. Missing the main > fuse, wing nuts holding spliced wires together (I don't think they are OEM), a > mess of electrical tape, and I can't figure out why. The car ran like this, > and i can't remember what did and did not work while it WAS running.
> I am
> rebuilding and want to get the electrical right. When I was attempting to > start the vehicle for the first time in quite some time, it shorted one of two > wires coming from the ac generator brush connected to the rotor assembly. WHY?
> I have taken out wiring between the rectifier, battery, voltage regulator, > and magnetic switch on the starter. I am going to replace every wire one at a > time to ensure the load is being transfered properly and all connections are > sound. I will snap a couple photos as it looks right now. ANY HELP IS > APPRECIATED! !!
deantds
Post by deantds »
hi i know this sounds dumb but i just got a replacement harnace from some one and used it and it took care of my problem. dean
Weight Loss Program
Best Weight Loss Program - Click Here!
http://thirdpartyoffers.netzero.net/TGL ... AEUgAAAAA=
Matt Trtan
Post by Matt Trtan »
Well that is what I was trying to avoid, and just use wire I already have on hand.  $$ saving.
HOWEVER, that is always an option, and perhaps the best one.  Now I just need to locate a spare harness.  It isn't the entire car's electrical harness that is messed up, only the cluster that I had mentioned.  Once it connects to the main harness that runs into the interior through the firewall it is okay.  As is the wiring to the lamps up front, fuel pump, heater etc.  Just the right front area under the hood.
deantds To:
Mon, January 25, 2010 1:23:49 PM Subject:
Re: [anzhonda600owners] Ignition/Charging circuit hi i know this sounds dumb but i just got a replacement harnace from some one and used it and it took care of my problem. dean
Weight Loss Program Best Weight Loss Program - Click Here!
http://thirdpartyoffers.netzero.net/TGL ... AEUgAAAAA= ------------------------------------
mterrens
Post by mterrens »
A used harness really be a timesaver.  If you can come up with a used harness, you can test the wires while the thing is out of the car, then just plug it all in!  The wiring harness for the engine bay is part 32101-568-674, shown as item #1 on pg 3-32 and 3-33 of the sedan parts catalog.  Maybe that ebay seller "eagle-hd" has one - I do not see one for sale now but it cannot hurt to write him.
> Matt
> Trtan
> Monday, January 25, 2010 2:33
> Well that is what I was trying to avoid, and just use wire I already have > on hand.  $$ saving.
> HOWEVER, that is always an option, and perhaps the best one.  Now I > just need to locate a spare harness.  It isn't the entire car's > electrical harness that is messed up, only the cluster that I had > mentioned.  Once it connects to the main harness that runs into the > interior through the firewall it is okay.  As is the wiring to the lamps > up front, fuel pump, heater etc.  Just the right front area under the > hood.
> deantds
> hi i know this
> sounds dumb but i just got a replacement harnace from some one and used it and > it took care of my problem.
> dean
> ____________ _________ _________ _________ _________ _________ ___ > Weight > Loss Program > Best Weight Loss Program - Click > Here!
> http://thirdpartyof fers.netzero. net/TGL2241/ c?cp=0Izm6emGtEQ LJEnSwEBhKQAAJ1E pcI-QoLrvX9mssDP j4x2bAAYAAAAAAAA AAAAAAAAAAADNAAA AAAAAAAAAAAAAAAA EUgAAAAA= > ------------ --------- --------- ------ > Yahoo!
> Groups Links
> To
mterrens
Post by mterrens »
A good harness to swap out to can really be a timesaver.  Then you get to use all the existing connectors, etc.  If you can come up with one, you can test the wires while the thing is out of the car, then just plug it all in!   Maybe that ebay seller "eagle-hd" has one - I do not see on for sale now but it cannot hurt to write him.
> Matt
> Trtan
> deantds
> hi i know this
> dean
> Groups Links
> To
paul tate
Post by paul tate »
You might check with Midwest Wholesale.  He has many listings for Honda 600 parts on ebay and I've purchased several items from him.with good luck.
Mon, 1/25/10, Steven Michelsen
> From: Steven Michelsen
> Subject: Re: [anzhonda600owners] Ignition/Charging circuit > To: anzhonda600owners@yahoogroups.com > Date: Monday, January 25, 2010, 1:41 PM
> A used harness really be a timesaver.  If you can come up with a used harness, you can test the wires while the thing is out of the car, then just plug it all in!  The wiring harness for the engine bay is part 32101-568-674, shown as item #1 on pg 3-32 and 3-33 of the sedan parts catalog.  Maybe that > ebay seller "eagle-hd" > has one - I do not see one for sale now but it cannot hurt to write him.
> Steve
> > Matt Trtan
> > Monday, January 25, 2010 2:33 PM
> > deantds
> > hi i know this sounds dumb but i just got a replacement harnace from some one and used it and it took care of my problem. dean > > ____________ _________ _________ _________ _________ _________ ___ > > Weight Loss Program > > Best Weight Loss Program - Click Here!
> > http://thirdpartyof fers.netzero. net/TGL2241/ c?cp=0Izm6emGtEQ LJEnSwEBhKQAAJ1E pcI-QoLrvX9mssDP j4x2bAAYAAAAAAAA AAAAAAAAAAADNAAA AAAAAAAAAAAAAAAA EUgAAAAA= > > ------------ --------- --------- ------
mterrens
Post by mterrens »
This is not the right one for your situation, but I see that a "wiring loom" may not cost so much...
> Matt
> Trtan
> deantds
> hi i know this
> dean
> Groups Links
> To
