1972 Honda Az600 finally on the road
RobertS
Post by RobertS »
Well my 72 Az600 coupe is finally rebuilt and driving. Thanks to all for the many tips that made this possible. I noticed the other day that although the hood latch mechanism works the bracket isn't mounted and I have no idea where it goes because the previous owner has a bolt through the bracket with a nut and two washers on it but I don't see anywhere to mount it to. I have loked both at the z600 coupe service manual and the parts manual but none are clear where it is mounted. Any and all help will be appreciated.
Re: 1972 Honda Az600 finally on the road
Are you wanting to know where it mounts (1) inside under the glove box or (2) the section which mounts under the hood?
> Well
> my 72 Az600 coupe is finally rebuilt and driving. Thanks to all for the many > tips that made this possible. I noticed the other day that although the hood > latch mechanism works the bracket isn't mounted and I have no idea where it > goes because the previous owner has a bolt through the bracket with a nut and > two washers on it but I don't see anywhere to mount it to. I have loked both > at the z600 coupe service manual and the parts manual but none are clear where > it is mounted. Any and all help will be > appreciated.
RobertS
Post by RobertS »
Dale,
Where the section that mounts under the hood. There is a bracket on the end of the cable cover but I don't know what it attaches to.
Bob
Bob,
The cable should have a black sheath which ends with an L-shaped bracket.
From the L-shaped bracket is a metal cable which goes to the hood latch plate in the middle of the chassis framing.  The L-shaped bracket connects at the ignition coil.  Use your 10mm wrench to remove the nut which secures the ignition coil to the chassis.  Place the L-bracket between the chassis and the ignition coil frame and then put the nut back on to secure everything.
> Where
> the section that mounts under the hood. There is a bracket on the end of the > cable cover but I don't know what it attaches to.
