2cylinderhondas@yahoogroups.com [mailto:
2cylinderhondas@yahoogroups.com] > On > Behalf Of > Kevin Keough > Sent:
> Friday, August 21, 2009 11:13
> RE:
> [2cylinderhondas] camshaft question
> hay tom check to see if the new cam is tapped to
> recieve the tac gear. that's is the diffrence in the two cams. you > may be able to have your repaired at a local cam shop or I have a > good one if you would email me Kevin > --- On > Sat, > 8/22/09, billmyong@earthlink .net
> > Subject: RE: [2cylinderhondas]
> > camshaft question
> > To: "Anzhonda600owners"
> > Date: Saturday, August
> > 22, 2009, 5:45 AM
> > All;
> > No, the cam shaft on the
> > coupe will work on the sedan, not the reverse unless you don't want > > the tach to work.
> > > 2cylinderhondas@
> > > yahoogroups. com [mailto:2cylinderho ndas@yahoogroups .com] > > > On > > > Behalf Of > > > Kevin Keough > > > Sent:
> > > 1:03 PM
> > > com
> > > Re: [2cylinderhondas] camshaft
> > > question
> > > yes
> > > --- On
> > > Fri, 8/21/09, franknfike
> > > wrote:
> > > > From:
> > > > franknfike > > > > Subject:
> > > > [2cylinderhondas] camshaft question > > > > To: 2cylinderhondas@ > > > > yahoogroups. com > > > > Date: Friday, August 21, 2009, 7:27 > > > > PM
> > > > Is the camshaft for the coupe the same as the sedan?
> > > > Thanks,
> > > > Tom
