DIfferential cover oil seal.
Does anyone know where to get a differential oil seal for a 72 az600 coupe? It is the large oil seal located in the differential cover.
Thanks
Thanks
blake neilson
Re: DIfferential cover oil seal.
If memory serves, that is a pretty standard seal, just take the seal to a bearing supply company, they also carry seals. If you can't find one look for an independent auto parts supply shop (not a PEP boys), usually located in an old downtown part of town. They can do the same.
Wed, 7/22/09, sangreyb
> From: sangreyb
> Subject: [anzhonda600owners] DIfferential cover oil seal.
> Date: Wednesday, July 22, 2009, 4:40 PM
> Thanks
You can also try a place like Kamen Bearing, but don't tell them it's for a car. These parts places are funny about what you use their products for.
> blake
> neilson
> Wednesday, July 22, 2009 6:00 PM
> Re: [anzhonda600owners]
> take the seal to a bearing supply company, they also carry > seals. If you can't find one look for an independent auto parts > supply shop (not a PEP boys), usually located in an old downtown part of > town. They can do the same.
> --- On
> Wed, 7/22/09,
> sangreyb
> > sangreyb
> > 22, 2009, 4:40 PM
> > Does anyone know where to get a differential oil seal for a 72 > > az600 coupe? It is the large oil seal located in the differential > > cover.
> > Thanks
Kamen said they have a seal but it is wrong width 10mm vice 7.5 mm. NOK has it but unsure if it will be available in a small quantity.
bob
bob
]On Behalf Of blake neilson
> Sent: Wednesday, July 22, 2009 6:00 PM
> Subject: Re: [anzhonda600owners] DIfferential cover oil seal.
> --- On Wed, 7/22/09, sangreyb wrote:
> From: sangreyb
> Thanks
Kevin Gailey
Coupe roof
Has anyone filled in the channels on a coupe roof, i.e. the rubber strip on top where it rusts. This seems like it would be a clean look, but not sure about rain runoff while driving. Would this effect value or structure of car. Does roof flex in this area? Also, I have seen some roofs with either vinyl or a satin black, any thought on this? I am doing body work as we speak. Nobody wanted to buy my car after I posted pics, so doing bodywork and painting first.
Kevin Gailey Early 72 Pop Orange Coupe From:
sangreyb To:
Thursday, July 23, 2009 11:38:19 AM Subject:
[anzhonda600owners] Re: DIfferential cover oil seal.
bob
sangreyb To:
bob
> From: sangreyb
> Thanks
Re: Coupe roof
ive seen these things where people bondo the seams and it cracks and it just ends up looking bad. if i were to do it, id weld metal strips over the seams and grind them down. That body line is kind part of what makes the car look so unique tho. and being a coupe, it seems like there shouldnt be a color separation for the top-seen a lot of them tho too. dont know to much about how it would affect the value. these cars seem to be worth the most when they are clean and stock. I say paint 'er up good and put a nice set of rims on it an go cruizin! There is a paint out there called 'Mirrachrome'. my brother and i are doing a 58 impala convertible in it and it mirrors chrome 98%. I had thought about doing mine in cobalt mirachrome but i know i dont have it in me to get the lines of the car back to perfect. if i had gone that route, i would have probably steel welded those strips on top in. at any rate, best of luck on Your paint -however You decide to go!
Thu, 7/23/09, Kevin Gailey
> From: Kevin Gailey
> Subject: [anzhonda600owners] Coupe roof
> Date: Thursday, July 23, 2009, 7:48 PM
> Kevin Gailey
> sangreyb
> bob
> , wrote:
> > You can also try a place like Kamen Bearing, but don't tell them it's for a > > car. These parts places are funny about what you use their products for.
> > [mailto:
> > If memory serves, that is a pretty standard seal, just take the seal to > > a bearing supply company, they also carry seals. If you can't find one > > look for an independent auto parts supply shop (not a PEP boys), usually > > located in an old downtown part of town. They can do the same.
> > --- On Wed, 7/22/09, sangreyb .> wrote:
> > From: sangreyb
> > Does anyone know where to get a differential oil seal for a 72 > > az600 coupe? It is the large oil seal located in the differential cover.
> > Thanks
Re: Coupe roof
Kevin;
This is where the panels are spot welded to gather, I have seen them covered and normally they have cracks. As to the vinyl roof treatment between the two sections. This was a dealer option and caused a bunch of roof problems on every one I saw. The windshield has to be removed and they curved under the back weather strip.
> Kevin
> Gailey
> Thursday, July 23, 2009 5:48 PM
> roof
> Has anyone filled in the channels on a coupe roof, i.e. the rubber strip > on top where it rusts. This seems like it would be a clean look, but not sure > about rain runoff while driving. Would this effect value or structure of > car. Does roof flex in this area? Also, I have seen some roofs with > either vinyl or a satin black, any thought on this? I am doing > body work as we speak. Nobody wanted to buy my car after I posted pics, > so doing bodywork and painting first.
> Kevin Gailey
> Early 72
> Pop Orange Coupe
> sangreyb
> seal.
> Kamen said they have a seal but it is wrong width 10mm vice 7.5 mm. NOK has > it but unsure if it will be available in a small > quantity.
> bob
> anzhonda600owners@
> yahoogroups. com
> , wrote:
> > You can
> car. These parts places are funny about what you use their products > for.
> anzhonda600owners@
> yahoogroups. com
> > [mailto:
> anzhonda600owners@
> yahoogroups. com
> 22, 2009 6:00 PM
> anzhonda600owners@
> yahoogroups. com
> cover oil seal.
> sangreyb wrote:
> > From: sangreyb
> oil seal.
> anzhonda600owners@
> yahoogroups. com
> seal for a 72
> differential cover.
> Thanks
Kevin Lister
What is a small quantity? Maybe a few of us could get together and buy a pile of them? ;o)
Thu, 7/23/09, sangreyb
> From: sangreyb
> Subject: [anzhonda600owners] Re: DIfferential cover oil seal.
> Date: Thursday, July 23, 2009, 11:38 AM
> bob
> > [mailto:
> > From: sangreyb
> > Thanks
Kevin Lister
Re: Coupe roof
Talk to Miles! ;o)
> From: Kevin Gailey
> Date: Thursday, July 23, 2009, 5:48 PM
> Kevin Gailey
> sangreyb
> bob
> > [mailto:
> > From: sangreyb
> > Thanks
Robert Goodrich
Re: Coupe roof
I had ask you if you ever lived and worked in San Diego CA. I used to work with a guy named Bill Young.
Bob
Bob
Fri, 7/24/09, billmyong@...
Subject: RE: [anzhonda600owners] Coupe roof
Date: Friday, July 24, 2009, 1:58 AM
Kevin;
> anzhonda600owners@ yahoogroups. com [mailto:anzhonda600 owners@yahoogrou ps.com] > On Behalf Of > Kevin Gailey > Sent:
> Kevin Gailey
> sangreyb
> bob
> > [mailto:
> > From: sangreyb
> > Thanks
