Yeah!
I finally hooked up the battery and the motor spins over nicely. I
checked the compression and one cylinder is 170 lbs and the other is
160 lbs on a cold engine that hasn't been running for about 4 years now.
Yes, I did squirt some oil into the spark plug holes first since this
has been sitting so long.
Which cylinder is considered #1?
I also decided to check for spark as I have also installed new points
too, but I have no spark, hmmm.
I also dont have any dash warning lights or radio, so I will start
checking my fuses to see if any are blown or if they have proper power
when the key is on. Hopefully it is related. I was hoping to have a oil
pressure light to see if it would go out when I cranked the engine over
as I have also changed the oil and filter on this too.
Is the coil supposed to have 12 volts at it? I'm guessing this may have
a magneto type system in it since it is related to a motorcylce motor
and I dont believe those need 12 volts, just a ground to kill the kill
the ignition when it is turned off.
I still need my accelerator pump diaphragm to re-install the carb and
that should be here next week sometime.
Mike
It cranks over !
Re: It cranks over !
--- In anzhonda600owners@yahoogroups.com, "geez_tech"
a rectifier, a set of points and a coil (and no magneto). Yes the
ignition switch suplies 12 volts, and no it does not kill by grounding.
It shuts down just the way a REAL car does, by removing battery voltage
from the circuitry and interrupting the fuel flow through the carb by
turning off the electric pump and allowing the fuel solenoid to close
and shut it off.
Hope that wasn't too preachy,
Mark
Well Mike, you appear to have guessed wrong. The 600 has an alternator,> a magneto type system in it since it is related to a motorcylce motor
> Mike
and shut it off.
Mark
Real car?
> Mark
> Sunday, July 27, 2008 12:23 AM
> [anzhonda600owners] Re:
> It cranks over !
> "geez_tech"
> I'm guessing this
> may have
> motorcylce motor
> ground to kill the
> kill
> off.
> > Mike
> has an alternator,
> magneto). Yes the
> kill by grounding.
> battery voltage
> the carb by
> turning off the electric pump and allowing the fuel solenoid > to close > and shut it off.
> preachy,
> Mark
Mike and Tami Speer
Not preachy at all, this will give me a good start today.
Thanks for the help and explanation.
Basically this is just like my air cooled VW then, except the motor is in the wrong spot.
J
Mike
J
Mike
mark cross
as for the statement about a magneto even the small Honda 50cc bikes
had a true 120 volt alternator that rectifies down to 6volts and uses
the ignition switch to turn off voltage. only thing that realy use
magnetos are lawnmower engines--- In
> Yeah!
> Mike
roger white
Magnetos are used on most piston powered aircraft engines. Two magnetos per engine, two sparkplugs per cylinder. Dual plugs give the engines 5% more power. They are considered to be more reliable as they will keep the engine running even with a dead battery. I hope thats the last I here of someone badmouthing the mighty magneto. :D
----- Original Message ---- From: mark cross To: anzhonda600owners@yahoogroups.com Sent: Monday, July 28, 2008 12:01:33 AM Subject: [anzhonda600owners] Re: It cranks over !
as for the statement about a magneto even the small Honda 50cc bikes had a true 120 volt alternator that rectifies down to 6volts and uses the ignition switch to turn off voltage. only thing that realy use magnetos are lawnmower engines--- In anzhonda600owners@ yahoogroups. com , "geez_tech" wrote:
is> Yeah!
> I finally hooked up the battery and the motor spins over nicely. I > checked the compression and one cylinder is 170 lbs and the other
now.> 160 lbs on a cold engine that hasn't been running for about 4 years
this> Yes, I did squirt some oil into the spark plug holes first since
also installed new points> has been sitting so long.
power> too, but I have no spark, hmmm.
> I also dont have any dash warning lights or radio, so I will start > checking my fuses to see if any are blown or if they have proper
oil> when the key is on. Hopefully it is related. I was hoping to have a
over> pressure light to see if it would go out when I cranked the engine
have> as I have also changed the oil and filter on this too.
motor> a magneto type system in it since it is related to a motorcylce
kill> and I dont believe those need 12 volts, just a ground to kill the
and> the ignition when it is turned off.
Mike> that should be here next week sometime.
