Closer to getting mine running
geez_tech
Post by geez_tech »
Hi all,
It has been a while but I have slowly collected some parts and I
have begun work on my N600, it may be running by next weekend, whoo
hoo!
I have done the basics so far, oil change, valve adjust (lubed the
rockers while the cover was off), new points and new fan belt. While
I had the pulleys off I removed the dust seal on the bearing and
lubed them with some distributor points grease as it is non melting.
Most everything shows signs that this car really has 30,000 miles on
it. The fan belt may have been original as it has Japenese words on
it, the fuel filter looks like it was never changed either, and one
tire has the '72 date code on it, and it is also a bias ply tire.
Tonight I verified the fuel pump works but the fuel smells like
turpentine, so that will be drained and re-filled with fresh fuel and
I will install some new fuel lines while everything is apart to be
safe, the original red ones are on it now.
I removed the carb and was surprised that the bowl was fairly clean,
no rust deposits in it, no gunk, no corrosion. But the acclerator
pump diaphram is fairly hard and not very flexible, I am soaking it
in engine oil to see if it may soften up some. Anything else on the
carb that I should look at closely?
I may get a battery this weekend so I can at least get some oil back
into the oil passages and also check for spark.
I have some questions though:
1. The fuel filter has a blue hose going from the filter to the pump,
it is still flexible, is this factory? The fuel hoses have a
cover/sleeve over them, do they need to remain on? Some are cracking
and may fall apart once I try to change the hoses.
2. Just curious, which way does the engine turn?
3. There is a "main" fuse on the passenger fender, is there supposed
to be a cover on it? Mine does not fit well in the bracket, but if it
was thicker it would be fine.
4. Underneath the passengers headlight there is a black box, is this
associated with the generator (alternator?)? Or is it a secondary
fuse box?
Thanks all,
Mike
Re: Closer to getting mine running
Hi Mike;
Welcome to the group.
Answers to your questions:
I am soaking it in engine oil to see if it may soften up some. Anything else on the carb that I should look at closely?
the accelerator pump is bad, will leak unless changed, soaking it in engine oil will do nothing for it.  Use a pin or very small wire and check out the hole from the accelerator pump into the fuel bowl.  Using carb-cleaner and compressed air check all the passageways.  Pull the needle valve and check to see if the spring loaded pin at the top of the needle is moving freely.  Be careful not to bend anything (It was running before, the settings should have been right) without pulling the jets, see if they are tight while in place.  If not then the O rings have shrunk and they will need replacing.  Same on the idle screw.....  Depending on the type of carb you have (there are two variations) the N600 manual has the early carb, while the Z600 supplement manual has the later version.
oil change  - No mention of changing the oil filter, change it.
1. The fuel filter has a blue hose going from the filter to the pump, it is still flexible, is this factory? The fuel hoses have a cover/sleeve over them, do they need to remain on? Some are cracking and may fall apart once I try to change the hoses. -
Fuel lines are covered with a heat shield material from factory.  Leave it in place if it is still good.  You can also purchase more.
2. Just curious, which way does the engine turn? - With a 17mm wrench move it from rear of the engine forward is the normal rotation.
3. There is a "main" fuse on the passenger fender, is there supposed to be a cover on it? Mine does not fit well in the bracket, but if it was thicker it would be fine.
 - Yes, there is supposed to be a cover.
4. Underneath the passengers headlight there is a black box, is this associated with the generator (alternator? )? Or is it a secondary fuse box?
- under the battery tray there is the rectifier, three wires in - one wire out.  If you look at the N600 shop manual Page 17-28 there is a good picture and description of how it works.
There are some other things you could do before resurrecting your old car (Honda 600).  Check the adjustment on the rockers (3mm feeler gauge goes under the rocker, 4mm won't) if they are to tight or to loose, readjust them.    Clean, reset your points, reattach or just pull all the connectors apart and put them back together (caution here, pull them apart with caution).  They have been sitting idle for many moons, corrosion will cause the connection to be much less or gone.  Pull the ground strap (Negative side of battery), under coil and bolted to the engine - clean everything (wire brush) and bolt back together, a good ground makes all the difference.   Check for rodent nests, and related wire damage.   If the steering seems loose, check the rack at the pinion shaft (at the point where it moves through the fire wall) pull back the carpet and watch the shaft as you move the steering wheel.  If it moves up-down back and forth...  without changing the position of the front wheels?  Then your pinion shaft bushings need to be changed out, not the tie rod ends!!
Have Fun, and be safe!
Brakes - bleed them fully, make sure good fluid is at all for wheels.  check for leaks, any sign, pull and rebuild.
> geez_tech
> Friday, July 18, 2008 9:54 PM
> [anzhonda600owners]
> Hi all,
> hoo!
> rockers while the cover was off), new points and new fan belt. While > I > had the pulleys off I removed the dust seal on the bearing and > lubed them > with some distributor points grease as it is non melting.
> Most everything
> with fresh fuel and
> apart to be
> I removed the
> no rust deposits in
> closely?
> I may get a battery this weekend so I can at least get some oil > back > into the oil passages and also check for spark.
> I have some
> questions though:
> filter to the pump,
> have a
> cover/sleeve over them, do they need to remain on? Some are > cracking > and may fall apart once I try to change the hoses.
> 2. Just
> 4.
> fuse box?
> Thanks all,
> Mike
mterrens
Post by mterrens »
Bill,
If the accelerator pump is rigid but not cracked or otherwise broken, how about soaking it in a cup of armor-all for a day or two?  If not that then some product designed for restoring rubber bits?
For a possible source of homemade, new accelerator pumps, try Bruce at theenginebuilder@...
> billmyong@...
> Saturday, July 19, 2008 8:18
> RE: [anzhonda600owners] Closer
> Hi
> Mike;
> I am soaking it
> in engine oil
> carb that I should
> look at closely?
> soaking it in engine oil will do nothing for it.  Use a pin or very small > wire and check out the hole from the accelerator pump into the > fuel bowl.  Using carb-cleaner and compressed air check all the > passageways.  Pull the needle valve and check to see if the spring loaded > pin at the top of the needle is moving freely.  Be careful not to bend > anything (It was running before, the settings should have been right) > without pulling the jets, see if they are tight while in place.  If not > then the O rings have shrunk and they will need replacing.  Same on the > idle screw.....  Depending on the type of carb you have (there are two > variations) the N600 manual has the early carb, while the Z600 supplement > manual has the later version.
> oil change  -
> No
> fuel hoses have a
> are cracking
> from factory.  Leave it in place if it is still good.  You can also > purchase more.
> turn? -
> fine.
>  - Yes, there is
> supposed to be a
> cover.
> fuse box?
> under the battery tray there is the rectifier, three wires in - one wire > out.  If you look at the N600 shop manual Page 17-28 there is a good > picture and description of how it works.
> things you could do before resurrecting your old car (Honda > 600).  Check the adjustment on the rockers (3mm feeler gauge goes > under the rocker, 4mm won't) if they are to tight or to > loose, readjust them.    Clean, reset your points, > reattach or just pull all the connectors apart and put them back together > (caution here, pull them apart with caution).  They have been sitting > idle for many moons, corrosion will cause the connection to be much less or > gone.  Pull the ground strap (Negative side of battery), under coil > and bolted to the engine - clean everything (wire brush) and bolt back > together, a good ground makes all the difference.   Check for > rodent nests, and related wire damage.   If the steering seems > loose, check the rack at the pinion shaft (at the point where it moves through > the fire wall) pull back the carpet and watch the shaft as you move the > steering wheel.  If it moves up-down back and forth...  without > changing the position of the front wheels?  Then your > pinion shaft bushings need to be changed out, not the tie rod > ends!!
> Have Fun, and be
> safe!
> Brakes - bleed them
> fully, make sure good fluid is at all for wheels.  check for leaks, any > sign, pull and rebuild.
> > On Behalf Of
> > geez_tech
> > [anzhonda600owners]
> > Hi all,
> > It has been a while but I have slowly collected some parts and > > I > > have begun work on my N600, it may be running by next weekend, whoo
> > hoo!
> > I have done the basics so far, oil change, valve adjust (lubed > > the > > rockers while the cover was off), new points and new fan belt. While
> > tire has the '72 date code on it, and it is also a bias ply > > tire.
> > I
> > may get a battery this weekend so I can at least get some oil back > > into > > the oil passages and also check for spark.
> > though:
> > 1. The fuel filter has a blue hose going from the filter to > > the pump, > > it is still flexible, is this factory? The fuel hoses have a
> > 2. Just
> > fine.
> > 4. Underneath the passengers headlight there is a black box, is > > this > > associated with the generator (alternator? )? Or is it a > > secondary > > fuse box?
> > Thanks all,
> > Mike
> Checked by AVG - http://www.avg.com
> Version: 8.0.138 / Virus Database: 270.5.0/1555 - Release Date: 7/16/2008 6:43 AM
geez_tech
Post by geez_tech »
Thanks Bill,
That explains my manual and carb, the pictures show a diaphram on the top of the carb with the domed bowl removed, mine does not have this. I am getting some carb and brake spray this weekend when I get the battery, and I also have a compressor so I can check all th passages as you mentioned. I was surprised at the condition of the bowl gasket, it looks very good and re-usable considering its age. Is there a source for gasket/rebuild kits? There was a guy on E-Bay selling some a while back but I wasn't sure if they were "homemade".
Yes, done and the old one was installed backwards with the dished part facing up towards the motor, the owners manual shows it facing down towards the cover. Besides E-Bay, is there another source for oil filter kits? I bought mine from Miles but he doesn't always seem to be selling on E-Bay. Surprisingly enough I found Napa to carry fuel filters and ignition condensors for these along with many other items that I may end up needing.
Where can I find these covers if mine break too much? Is that plastic blue hose on the fuel filter a factory hose or maybe a "emergency" repair?
them.
 I did that already and were a little bit loose, good to find as I was afraid they would be tight and possibly burned. Odd adjustment procedure with the lock bolt and turning the shaft, I take it it as eccentric set up?
New points installed, lubed with points grease and the timing is set as per the owners manual. I also tested the vacuum advace and that also is working. Any connector removed as been sanded lightly to get rid of the corrosion/oxidation you mention although most of the wires and connections are in good shape. I will probably replace the condensor wire (blue wire) as the sheathing is coming off of it, I just need to find a new spade connector first.
  Thanks for the extra tips, I will check those out this weekend.
Mike
--- In anzhonda600owners@yahoogroups.com, wrote:
> Hi Mike;
> Answers to your questions: I am soaking it
> in engine oil to see if it may soften up some. Anything else on the > carb that I should look at closely? the accelerator pump is bad, will leak > unless changed, soaking it in engine oil will do nothing for it. Use a pin > or very small wire and check out the hole from the accelerator pump into the > fuel bowl. Using carb-cleaner and compressed air check all the passageways.
> Pull the needle valve and check to see if the spring loaded pin at the top > of the needle is moving freely. Be careful not to bend anything (It was > running before, the settings should have been right) without pulling the > jets, see if they are tight while in place. If not then the O rings have > shrunk and they will need replacing. Same on the idle screw..... Depending > on the type of carb you have (there are two variations) the N600 manual has > the early carb, while the Z600 supplement manual has the later version.
> 1. The fuel filter has a blue hose going from the filter to the pump, > it is still flexible, is this factory? The fuel hoses have a > cover/sleeve over them, do they need to remain on? Some are cracking > and may fall apart once I try to change the hoses. - Fuel lines are covered > with a heat shield material from factory. Leave it in place if it is still > good. You can also purchase more.
> 2. Just curious, which way does the engine turn? - With a 17mm wrench move > it from rear of the engine forward is the normal rotation.
> 3. There is a "main" fuse on the passenger fender, is there supposed > to be a cover on it? Mine does not fit well in the bracket, but if it > was thicker it would be fine. - Yes, there is supposed to be a cover.
> 4. Underneath the passengers headlight there is a black box, is this > associated with the generator (alternator?)? Or is it a secondary > fuse box? - under the battery tray there is the rectifier, three wires in - > one wire out. If you look at the N600 shop manual Page 17-28 there is a > good picture and description of how it works.
> There are some other things you could do before resurrecting your old car > (Honda 600). Check the adjustment on the rockers (3mm feeler gauge goes > under the rocker, 4mm won't) if they are to tight or to loose, readjust > them. Clean, reset your points, reattach or just pull all the connectors > apart and put them back together (caution here, pull them apart with > caution). They have been sitting idle for many moons, corrosion will cause > the connection to be much less or gone. Pull the ground strap (Negative > side of battery), under coil and bolted to the engine - clean everything > (wire brush) and bolt back together, a good ground makes all the difference.
> Check for rodent nests, and related wire damage. If the steering seems > loose, check the rack at the pinion shaft (at the point where it moves > through the fire wall) pull back the carpet and watch the shaft as you move > the steering wheel. If it moves up-down back and forth... without changing > the position of the front wheels? Then your pinion shaft bushings need to > be changed out, not the tie rod ends!!
> Brakes - bleed them fully, make sure good fluid is at all for wheels. check > for leaks, any sign, pull and rebuild.
> From: anzhonda600owners@yahoogroups.com
> [mailto:anzhonda600owners@yahoogroups.com]On Behalf Of geez_tech > Sent: Friday, July 18, 2008 9:54 PM > To: anzhonda600owners@yahoogroups.com > Subject: [anzhonda600owners] Closer to getting mine running
> Hi all,
> It has been a while but I have slowly collected some parts and I > have begun work on my N600, it may be running by next weekend, whoo > hoo!
> I have done the basics so far, oil change, valve adjust (lubed the > rockers while the cover was off), new points and new fan belt. While > I had the pulleys off I removed the dust seal on the bearing and > lubed them with some distributor points grease as it is non melting.
> Most everything shows signs that this car really has 30,000 miles on > it. The fan belt may have been original as it has Japenese words on > it, the fuel filter looks like it was never changed either, and one > tire has the '72 date code on it, and it is also a bias ply tire.
> Tonight I verified the fuel pump works but the fuel smells like > turpentine, so that will be drained and re-filled with fresh fuel and > I will install some new fuel lines while everything is apart to be > safe, the original red ones are on it now.
> I removed the carb and was surprised that the bowl was fairly clean, > no rust deposits in it, no gunk, no corrosion. But the acclerator > pump diaphram is fairly hard and not very flexible, I am soaking it > in engine oil to see if it may soften up some. Anything else on the > carb that I should look at closely?
> I may get a battery this weekend so I can at least get some oil back > into the oil passages and also check for spark.
> Thanks all,
> Mike
mterrens
Post by mterrens »
The oil filter just about the one and only part I ever got from my local Honda dealer.
Just call them up and ask for part # 06154-551-505.  They may tell you at first that it is not a valid part number.  Push them to look further.  Then after some mild surprise, they will tell you that it needs to be ordered and they'll have it in a few days.  Usually about $9 for the filter, which comes packaged with a set of rubber washers.
I suggest you buy a few.
Steve www.honda600coupe.com
> geez_tech
> Saturday, July 19, 2008 2:26
> [anzhonda600owners] Re: Closer
> Thanks Bill,
> of carb you have (there are two variations) the N600 manual has >  the > early carb, while the Z600 supplement manual has the later version.
> That explains my manual and carb, the pictures show a diaphram > on the top of the carb with the domed bowl removed, mine does not have this. I > am getting some carb and brake spray this weekend when I get the battery, and > I also have a compressor so I can check all th passages as you mentioned. I > was surprised at the condition of the bowl gasket, it looks very good and > re-usable considering its age. Is there a source for gasket/rebuild kits?
> There was a guy on E-Bay selling some a while back but I wasn't sure if they > were "homemade".
> filter, change it.
> with the dished part facing up towards the motor, the owners manual shows it > facing down towards the cover. Besides E-Bay, is there another source for oil > filter kits? I bought mine from Miles but he doesn't always seem to be selling > on E-Bay. Surprisingly enough I found Napa to carry fuel filters and ignition > condensors for these along with many other items that I may end up > needing.
> Fuel lines are
> covered with a heat shield material from factory. Leave it in place if it is > still >  good. You can also purchase more.
> Where can I find these covers if mine break too much? Is that > plastic blue hose on the fuel filter a factory hose or maybe a > "emergency" repair?
> goes under the rocker, 4mm won't) if they are to tight or to loose, > readjust
> them.
>  I did that already and were a little bit loose, good to find > as I was afraid they would be tight and possibly burned. Odd adjustment > procedure with the lock bolt and turning the shaft, I take it it as eccentric > set up?
> connectors apart and put them back together (caution here, pull them apart > with caution). They have been sitting idle for many moons, corrosion will > cause the connection to be much less or gone.
> New points installed, lubed with points grease and the timing is set as per > the owners manual. I also tested the vacuum advace and that also is working.
> Any connector removed as been sanded lightly to get rid of the > corrosion/oxidation you mention although most of the wires and connections are > in good shape. I will probably replace the condensor wire (blue wire) as > the sheathing is coming off of it, I just need to find a new spade connector > first.
> weekend.
> Mike
> > Hi Mike;
> > unless changed,
> soaking it in engine oil will do nothing for it. Use a pin > > or very > small wire and check out the hole from the accelerator pump into the
> > oil change - No
> > 1. The fuel
> filter has a blue hose going from the filter to the pump, > > it is still > flexible, is this factory? The fuel hoses have a > > cover/sleeve over > them, do they need to remain on? Some are cracking > > and may fall apart > once I try to change the hoses. - Fuel lines are covered > > with a heat > shield material from factory. Leave it in place if it is still > > good.
> > 4. Underneath the
> > associated with the
> > one wire out. If
> > good picture
> > them. Clean, reset
> > apart and put
> > caution). They
> have been sitting idle for many moons, corrosion will cause > > the > connection to be much less or gone. Pull the ground strap (Negative
> side of battery), under coil and bolted to the engine - clean > everything > > (wire brush) and bolt back together, a good ground makes > all the difference.
> > be changed out, not
> the tie rod ends!!
> rebuild.
> > -----Original
> Message-----
> [mailto:anzhonda600owners@yahoogroups.com]On Behalf Of geez_tech > > Sent:
> > Hi all,
> > It has been
> > have begun work
> > hoo!
> > I
> rockers while the cover was off), new points and new fan belt. While > > I > had the pulleys off I removed the dust seal on the bearing and > > lubed > them with some distributor points grease as it is non melting.
> > Most
> everything shows signs that this car really has 30,000 miles on > > it.
> The fan belt may have been original as it has Japenese words on > > it, > the fuel filter looks like it was never changed either, and one > > tire > has the '72 date code on it, and it is also a bias ply tire.
> > Tonight I
> > turpentine, so
> > I will install
> > safe, the original
> But the acclerator
> I am soaking it
> > I may
> get a battery this weekend so I can at least get some oil back > > into > the oil passages and also check for spark.
> > I have some
> questions though:
> hoses.
> turn?
> there supposed
> bracket, but if it
> > 4.
> associated with the generator (alternator?)? Or is it a secondary > > fuse > box?
> > Thanks all,
> > Mike
> Version: 8.0.138 / Virus Database: 270.5.1/1560 - Release Date: 7/18/2008 6:47 AM
Hi Steve,
     Can you tell me the city, name, and phone # of the Honda dealer where you purchase your oil filters?
thanks,
> The oil
> filter just about the one and only part I ever got from my local > Honda > dealer.  Just call them up and ask for part # > 06154-551-505.  They may tell > you at first that it is not a valid part > number.  Push them to look further.  Then after some > mild > surprise, they will tell you that it needs to be ordered and they'll > have it > in a few days.  Usually about $9 for the filter, which comes > packaged with a > set of rubber washers.
> I suggest you buy a
> few.
Get fantasy football with free live scoring.
Sign up for FanHouse Fantasy Football today .
Mike;
I found a fuel line insulation kit in J.C Whitney catalong on Page 205 of Catalog #700J-07.  Part number WG377543R for $13.99.
I have used a Honda Goldwing carb kit from the early 70's will work.  But they didn't have an accelerator pump.
Correct, and normally owners over tighten the bolt.  Factory specs ate there for a purpose and to much torque can cause other problems.   So always recheck settings before saying your done.
Good check on the Blue wire in the distributor.  Also look at the breaker plate, if there is side movement it may need to be repaired.   Go to the Yahoo Group site for ANZhonda600ownres in the text section.
> geez_tech
> Saturday, July 19, 2008 11:26 AM
> Thanks Bill,
> filter, change it.
> Fuel lines are
> them.
> weekend.
> Mike
> --- In anzhonda600owners@ yahoogroups. com,
> > Hi Mike;
> > Welcome to
> the group.
> carb that I should look at closely? the accelerator pump is bad, will > leak > > unless changed, soaking it in engine oil will do nothing for it.
> Use a pin
> > shrunk and they
> will need replacing. Same on the idle screw..... Depending > > on the type > of carb you have (there are two variations) the N600 manual has > > the > early carb, while the Z600 supplement manual has the later version.
> > oil change - No mention of changing the oil filter, change > it.
> > 1. The fuel filter has a blue hose going from the filter > to the pump, > > it is still flexible, is this factory? The fuel hoses > have a > > cover/sleeve over them, do they need to remain on? Some are > cracking > > and may fall apart once I try to change the hoses. - Fuel > lines are covered > > with a heat shield material from factory. Leave it > in place if it is still > > good. You can also purchase more.
> > 2. Just curious, which way does the engine turn? - With a 17mm wrench > move > > it from rear of the engine forward is the normal > rotation.
> > 3. There is a "main" fuse on the passenger fender, is there > supposed > > to be a cover on it? Mine does not fit well in the bracket, > but if it > > was thicker it would be fine. - Yes, there is supposed to be > a cover.
> black box, is this
> works.
> > side of battery),
> > (wire brush)
> > Check
> through the fire wall) pull back the carpet and watch the shaft as you > move > > the steering wheel. If it moves up-down back and forth... without > changing > > the position of the front wheels? Then your pinion shaft > bushings need to > > be changed out, not the tie rod ends!!
> check
> [mailto:anzhonda600 owners@yahoogrou ps.com]On Behalf Of > geez_tech > > Sent: Friday, July 18, 2008 9:54 PM > > To:
> Hi all,
> > It has been a while but I have slowly collected some parts and > I > > have begun work on my N600, it may be running by next weekend, > whoo > > hoo!
> adjust (lubed the
> fan belt. While
> bearing and
> non melting.
> 30,000 miles on
> Japenese words on
> either, and one
> bias ply tire.
> smells like
> fresh fuel and
> apart to be
> > I
> removed the carb and was surprised that the bowl was fairly clean, > > no > rust deposits in it, no gunk, no corrosion. But the acclerator > > pump > diaphram is fairly hard and not very flexible, I am soaking it > > in > engine oil to see if it may soften up some. Anything else on the > > carb > that I should look at closely?
> for spark.
> > 1.
> The fuel filter has a blue hose going from the filter to the pump, > > it > is still flexible, is this factory? The fuel hoses have a > > cover/sleeve > over them, do they need to remain on? Some are cracking > > and may fall > apart once I try to change the hoses.
> fine.
> box, is this
> it a secondary
> > fuse box?
> > Thanks all,
> Mike
mterrens
Post by mterrens »
doesn't matter.  they looked it up in a database that all dealers have and ordered it from a centrall location.
FWIW, Joyce Honda, Denville, NJ
> goinhm@...
> Sunday, July 20, 2008 3:22 AM
> Re: [anzhonda600owners] Re:
> Hi Steve,
> thanks,
> > The oil
> > filter just about the one and only part I ever got from my local > > Honda > > dealer.  Just call them up and ask for part # > > 06154-551-505.  They may tell > > you at first that it is not a valid > > part number.  Push them to look further.  Then after some > > mild > > surprise, they will tell you that it needs to be ordered and they'll > > have it > > in a few days.  Usually about $9 for the filter, which comes > > packaged with a > > set of rubber washers.
> > I suggest you buy a
> > few.
> today
> Version: 8.0.138 / Virus Database: 270.5.2/1562 - Release Date: 7/19/2008 2:01 PM
Thanks, Steve.
Although it may be in a common database,  when I talked to the local dealer near me, they were not very helpful.  When I talk to them again,  if they cannot figure it out,   I'll have my local person talk to the parts person at Joyce to learn the system.   Or maybe I'll order the part through Joyce Honda and have it available for pickup at the place where I live.
> doesn't matter.  they looked it up in a database that all dealers > have and ordered it from a centrall location.
> NJ
Mike and Tami Speer
Post by Mike and Tami Speer »
When calling a dealer it may be best to have the part numbers ready and don’t mention what car it is for, I will be trying this with my local Honda dealer. The young ones may just tell you they can’t get it once they hear ‘72, the ones that have been around for a while may be more inclined to help. I went through this with a VW dealer for my air cooled, if it is available and they can get it then they should look it up and order it.
Mike
