Correct, I said the crank shaft is weak. My question is if the rods and pins for the CB450 are the same as the N600. The cam chain is another story and there are ways of dealing with it. The Oil pump rod is another link in the list of weak parts in the Honda 600 engine, but that too can be put in it's place with good machine work. The crankshaft is another area.
As far as the carb goes, your right about the O rings. The alcohol in the fuel we are forced to use a the pump eats the natural rubber O rings and the nylon bushing on the shafts causing all kinds of problems. But, as you said, the design is 1970's and we didn't have the fuel problems we are dealing with today. Are there any O rings made that will withstand the effects of the combined fuel?
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > Zay Speed > Sent:
> Saturday, March 15, 2008 4:58
> RE:
> [2cylinderhondas] Re: dual output coil from summit
> Hi Bill
> Not sure about the connecting rods or crank
> I have never needed to replace them before. No I did not say > the crank > shaft was the week link it is the Timing Chain that runs from crank to > cam The stock one stretches way bad.
> They use a lighter out put wey stator
> on the CB 450 so there is a chance the crank end might be different, But I > would > think they would have made rotor fit the crank they already > had.
> The most important thing is changing out that cam
> chain and getting future points & condensers. The carb is a bit > diffrent > But you can cross over the carb main jet to next size down as > they tend to run a little rich. You can get all the "O Rings" at a place that > sells or makes O rings they are very important change the get hard and let > fuel flow past and choking out the motor, honda will not sell the O rings but > you can buy a "K & N " carb rebuild kit for about $18.00 and it will come > with a lot of what you need K & N also sells cam chain and master > link > :::::::::::: ::::::::: ::::::::: ::::::::: ::::::::: ::::::::: ::::::::: Zay J. Speed
> > billmyong@earthlink .net
> > Date: Sat, 15 Mar 2008 13:33:38
> > -0700
> > Subject: RE: [2cylinderhondas] Re: dual output coil from > > summit
> > Zay;
> > You are correct, and I agree with all you say about the design of the > > car. Weak link is the crank shaft. If what you say about > > the 450 is correct (I dont know) then is the crankshaft rods and pins the > > same?
> > On Behalf Of
> > zayjspeed
> > Friday, March 14, 2008 2:15
> > PM
> > "infinkc" wrote:
> > > summit racing has
> > a dual output coil, has anyone had experience
> > with
> > > one of these
> > replacing the stock coil? Im debating using my stock > > coil > > > with > > my EFI setup. Also im looking for an electronic
> > points/condenser,
> > > i saw the one Jpro has on evil
> > tweety. any others out there? Jpro
> > can
> > > i get your contact info,
> > i have a few questions about your setup.
> > > I found a diagram
> > to use the stock points to trigger a external
> > > electronic ignition i
> > might give that a try as a cheap easy
> > alternative.
> > Hi My name
> > Zay Speed I have been a professional motorcycle mechanic > > for over 30 > > years and worked on lots of "600's" "Accel" > > http://www.accel- motorcycle. com/PressRelease s.aspx?BrandID= 9
> > offers a coil in there motorcycle line that works very well for a
> > point system. I use their coil replacements on all motorcycles that I
> > repair with secondary coil loss, they are way better than stock and
> > much cheaper. Keep in mind that the 600 motor is a "1968 Honda CB 450
> > motorcycle" with a weird trany stuck on it. As far as a pointless
> > system not sure, cars like vacuum advance, not common on bikes you
> > could use a "side by side twin" motorcycle after market
> > "Inductive"
> > or "CDI" but you would lose the vacuum advance. Coil's are > > sensitive > > to ignition type / points / CDI / inductive/ ect. For the > > performance > > out put of this thing the point system works good and is > > quite cheap!
> > you just gota adjust you're valves / change oil & filter > > / clean & gap > > points / check timing every 2,500 miles its part of the > > cars > > design > > :::::::::::: ::::::::: ::::::::: ::::::::: :::Zay
