Re: [2cylinderhondas] 72 Honda 600 coupe (Yellow)
I have said this before, but it needs to be said again.  In the past many years, I have worked on Honda 600's I have only had one coil I couldn't get working. The small wires can be soldered back on, the high tension wires can be changed out.   This is a 30 some year old car with 30 year old technology getting it down the road.  And almost every Honda Car left has the capability of getting back on the road.
> Tuesday, April 03, 2007 4:34
> [2cylinderhondas] 72 honda 600 coupe (Yellow)
> I was looking at your msg and noticed you comment about the coil. You think
> you have a bad coil? The 600 website has an article about adding new ign
> wires to the coil. I suspect the coil is good but the high voltage cables > may > be defective or it may not be getting voltage to the primary of the > coil. Or > the line from the coil to the breaker plate may need > checking/rework.
> If you need a coil, check ebay, get a motorcycle-style
> coil (e.g. Accel),
> or rig up your own. My friend removed the Honda coil
> and used a pair of 12
> volt auto ign coils. He tied both primary leads of
> the two coils to the
> points and the HV secondaries went to the 2 spark
> plugs. It worked and he never
> had any problems which surprised me. I would
> have expected the two coils to
> cause a large current draw on the points
> and would have expected him to be
> replacing points more
> frequently.
> See what's free at
> http://www.aol. com.
> [Non-text
> portions of this message have been removed]
