Re: [2cylinderhondas] choke on Coupe doesn't stay put
Steve, Zman,
The early chokes didn't have an adjustment.  These were the one's that had the chrome cap.  The choke with the black outer cap can be adjusted.  For the early unit, don't tighten the back nut, you will brake the threaded area of the plastic.  Rather, unscrew the nut from the back side and pull it toward you about an inch or so to see the 1/8th in. square hole.  (or the nylon strip may still be there) pull it our and/or cut another to replace it and screw it back together.  The nylon strip is what keeps the choke out and allows it to slowly move in.  Over time it wares out.
> whitesrus@...
> [mailto:whitesrus@...]
> Wednesday, November 10, 2004 9:17
> Steve.
>    Have you tried adjusting the hold down
> nut at the dash face. Turn
> Clockwise slightly
> for more
> resistance.
> Zman
> Steven Michelsen
> [mailto:stevenm@...]
> 11/10/2004 11:34:13 AM
> anzhonda600owners@yahoogroups.com;2cylinderhondas@yahoogroups.com
> put
> I find that when I pull the choke out on my Coupe, then
> start the car, the choke tends to drift back towards the dash on it's own. I > need to hold it out while the car warms up. Is there an adjustment to keep the > choke cable from moving on it's own after it is pulled out?
> While on the topic, how long should it typically take before > the 600 can idle on it's own (no choke) on a cold day? And without a tach > (note: Coupe with sedan engine), how does one pick the proper idle speed? I > just set it to idle "just fast enough" to avoid stalling.
> Steve
> Yahoo! Groups
> Sponsor
> Get unlimited calls to
> U.S./Canada
Note: 3 image(s) originally linked in this post are no longer available (ec, ec, rand=996754400).
mterrens
Post by mterrens »
Yes, mine has the chrome cap.  I did reach around and find the back nut; I already tightened it slightly as there was a lot of slack - didn't turn it enough to create a problem.  I will back out the nut, look at the condition of things and report back.
Thanks, Steve
> william
> colford
> Thursday, November 11, 2004 2:58
> [anzhonda600owners] RE:
> Steve, Zman,
> were the one's that had the chrome cap.  The choke with the black outer > cap can be adjusted.  For the early unit, don't tighten the back nut, you > will brake the threaded area of the plastic.  Rather, unscrew the nut > from the back side and pull it toward you about an inch or so to see the 1/8th > in. square hole.  (or the nylon strip may still be there) pull it our > and/or cut another to replace it and screw it back together.  The nylon > strip is what keeps the choke out and allows it to slowly move in.  Over > time it wares out.
> > whitesrus@...
> > 9:17 AM
> > Re:
> > Steve.
> > down nut at the dash face. Turn
> > Clockwise slightly
> > for more
> > resistance.
> > Zman
> > Steven Michelsen
> > put
> > start the car, the choke tends to drift back towards the dash on it's own. I > > need to hold it out while the car warms up. Is there an adjustment to keep > > the choke cable from moving on it's own after it is pulled out?
> > before the 600 can idle on it's own (no choke) on a cold day? And without a > > tach (note: Coupe with sedan engine), how does one pick the proper idle > > speed? I just set it to idle "just fast enough" to avoid > > stalling.
> > Thanks,
> > Steve
> > Yahoo! Groups
> > Sponsor
> > U.S./Canada
