Hi Dean;
Some times it's a ground issue. look at the black wire going into the
voltage regulator, and pull the plug apart and look for corrosion. Then
look at the ground wire coming from the voltage regulator to the bolt.
Unscrew the bolt and clean the attaching surface. A Volt meter on the Ohm
scale can check out the rectifier to see if it is acting like a diode should
(only letting current travel one way. Check all the connections from the
stator to the regulator. Pull them apart and clean them, then check for
continuity. The Large Shop manual gives some very good tests.
Look around, you will be surprised at what you will find just pulling things
apart.
Re: [2cylinderhondas] charging
deanbratcher1
thanks for the info,I'll check the ground tomorrow.But if i don't remember a ground coming off of the regulator.Also i got a regulator at Autozone that they had listed for this car but it has a different conection.Did they change the conections, or did autozone just have the wrong part number.(i've got brake shoes and pads, and a fan belt there and they were right but you never can tell) This all seemed to start when the fly wheel came off last week, could that have damaged anything?
Thanks for the help
Dean
Thanks for the help
Dean
> william
> colford
> Wednesday, October 01, 2003 1:23
> [anzhonda600owners] Re:
> Hi Dean;
> look at the ground
> scale can check
> out the rectifier to see if it is acting like a diode should > (only letting > current travel one way. Check all the connections from the > stator to > the regulator. Pull them apart and clean them, then check > for > continuity. The Large Shop manual gives some very good > tests.
> Look around, you will be surprised at what you will find just > pulling things > apart.
> ----- Original
> Message -----
> From: "wmdbratcher"
> Sent: Tuesday, September 30, 2003
> 11:12 AM
> Subject: [2cylinderhondas] charging
> I'm getting nothing
> out of the generator. How should I go about
> testing it.I'm pretty sure the
> voltage regulator is fine.Also how do
> you test the rectifier, and what
> exactly does it do?
> Thanks
> Dean
> To unsubscribe from this
> group, send an email
> to:
> Your use of
> Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
> To
> to:
> Your
> Yahoo! Terms of Service
riceburner006
--- In anzhonda600owners@yahoogroups.com, "deanbratcher1"
anything?
Yes! They coukd have damaged the brush assembly. riceburner006
remember a ground coming off of the regulator.Also i got a regulator> thanks for the info,I'll check the ground tomorrow.But if i don't
anything?
anzhonda600owners@yahoogroups.com> Thanks for the help
> Dean
> From: william colford
> Sent: Wednesday, October 01, 2003 1:23 AM
> Subject: [anzhonda600owners] Re: [2cylinderhondas] charging
> Hi Dean;
> apart.
> From: "wmdbratcher"
> To: Sent: Tuesday, September 30, 2003 11:12 AM
> I'm getting nothing out of the generator. How should I go about
> testing it.I'm pretty sure the voltage regulator is fine.Also how do
> you test the rectifier, and what exactly does it do?
> Thanks
> Dean
> Yahoo! Groups Sponsor
> ADVERTISEMENT
Hi Dean;
Check the brushes, they may be broken or nolonger making contact.
> deanbratcher1
> Wednesday, October 01, 2003 3:09
> Re: [anzhonda600owners] Re:
> tomorrow.But if i don't remember a ground coming off of the regulator.Also i > got a regulator at Autozone that they had listed for this car but it has a > different conection.Did they change the conections, or did autozone just have > the wrong part number.(i've got brake shoes and pads, and a fan belt there and > they were right but you never can tell) This all seemed to start when the fly > wheel came off last week, could that have damaged anything?
> Thanks for the help
> Dean
> > william colford
> > AM
> > Hi Dean;
> > Some times it's a
> > ground issue. look at the black wire going into the > > voltage > > regulator, and pull the plug apart and look for corrosion.
> > Then
> > look at the ground wire coming from the voltage regulator to the > > bolt.
> > Unscrew the bolt and clean the attaching surface. A Volt > > meter on the Ohm > > scale can check out the rectifier to see if it is acting > > like a diode should > > (only letting current travel one way. Check all > > the connections from the > > stator to the regulator. Pull them apart > > and clean them, then check for > > continuity. The Large Shop manual > > gives some very good tests.
> > things
> > apart.
> > ----- Original Message
> > From: "wmdbratcher"
> > 11:12 AM
> > I'm getting
> > Thanks
> > Dean
> > To unsubscribe
> > to:
> > Your use
> > To
> > to:
> > Your
> To
> to:
> Your
