Bill,Is there anything different about removing/replacing a coupe
engine Vs. a sedan? It seems to have less clearance between the
firewall and grill. I was wondering if there was any tips that could
make the job easier. I read the files you have,but I use jackstands
and a transmission jack. (Can't lift the body).riceburner006.
R&R powerplants
Re: R&R powerplants
Well, put the struts in first, then the front subframe bolts then the rear
bolts (all hand tight) then tighten it all up. A lot easier than a sedan.
