Fw: [2cylinderhondas] weatherstripping
[No content]
Mikey
Re: Fw: [2cylinderhondas] weatherstripping
Post by Mikey »
Hello Bill, do you need just one kit to do both doors or will i need
to order 2? and that was item #3 right? Any suggestions as for the
seal for the trunk?
Thanks Mikey
Hi Mikey
One kit for both doors, I use the square weather stripping you can buy from
the hardware store for the trunk. Adhesive back and all. It also works for
the bottom of the doors. The bulb rubber should not be used all the way
around.
