Re: [2cylinderhondas] fan belt
Hi Nick;
No, you could pull the Battery, then loosen the lower wheel of the two,
push it toward the fan, remove the old belt. Double the new belt and push
it in to the fan opening tuck the lower part of the belt down and up over
the lower wheel and the other on the upper wheel and down to the crankshaft
pulley. pull the lower wheel toward the battery and tighten the nut.
Remember to hold the belt together as in the belt tightening instructions.
Your set.
