Rear Light Bulbs
Brian Bates
Rear Light Bulbs
Post by Brian Bates »
Does anyone know the correct bulb numbers for the rear tail lamps & backup lamps?
Brian D. Bates, PSS, CST
WDNR Assured Wetland Delineator
Bates Soil & Water Testing Services
XXX-XXX-XXXX
Sent from my iPhone
dusty path
Re: Rear Light Bulbs
Post by dusty path »
rear lights are 1157 and the back up are 1156  but I go LED as I did  did on all the lights  other then  front turn  lights   led bulbs will not fit   the hole too deep  u can buy the LEDs  from walmart  if your in the USA if not ebay works for me
On Saturday, July 7, 2018, 9:52:35 AM MST, Brian Bates bates.brian@... [2cylinderhondas] wrote:
XXX-XXX-XXXX
Sent from my iPhone
JGraf
Post by JGraf »
The original number for the tail lamps is 1034, the original backup lamps are 1073. However, I prefer the European P21/5W and P21W respectively as their current draw is lower (less heat) and they are slightly brighter. The main disadvantage is a shorter lifetime but since most of these cars aren't daily drivers that may not be a concern.
On Saturday, July 7, 2018 11:52:34 AM CDT, Brian Bates bates.brian@... [2cylinderhondas] wrote:
XXX-XXX-XXXX
Sent from my iPhone
