When I have needed to work on the ignition switch, I have dropped the steering column which gives access to the 2 screws holding the switch. The switch collar has an anti-theft design which makes it difficult to remove it.
In a message dated 9/14/2015 7:37:03 P.M. Pacific Daylight Time, 2cylinderhondas@yahoogroups.com writes:
Note: 1 image(s) originally linked in this post are no longer available (fpc.pl).> Does anyone have an NOS or good used ignition switch, or can anyone > provide advice as to how to repair mine. The spring that returns the key from > the start position does not work, so that the switch tends to remain in the > start position.
> Are the switches easy to replace? How do you remove the switch > collar and is it a shear bolt with rounded or recessed heads. If so, how do > you grab it to remove the switch?
> Thanks in advance for all of your help.
> Chas
> Sent from my iPad
> > Reply
> > via web post
> > Reply
> > to sender
> > Reply
> > to group
> > Start
> > a New Topic
