1. The stock fan moves a lot of air and it is variable speed.
The electric fans being suggested are not moving enough air.
2. The stock fan has a specially designed cooling shroud which is pulling air across a large number of fins in the cylinder barrels. What are you using for the electric fan?
3. While the electric fan may do a good job when you are stopped or moving slowly, how well is it working when you are travelling at 60 mph? And is it allowing the air to properly move across the fins or is it impeding the air flow?
4. The stock plastic fan and belt assembly is such a small mass that it requires very little power to operate. The fan belts don't wear out due to use as much as they come apart due to aging.
5. I don't think the electric fan gives you a horsepower gain unless it is not operating. The stock system is a mechanical transfer to a low mass system. The electric fan is running off of electricity which must be supplied by the engine's electrical system. So, you have a mechanical system driving an electrical generating system to operate an electric fan which is driving a mechanical fan. How can that be more efficient than a direct mechanical connection? If both fans (the stock system and the electric fan) are moving the same air volume, the stock system must be more efficient.
And for the person who says "my dragster uses an electric fan because I want more horsepower to the wheels". We are not talking the same thing. Your dragster has a battery on board which is not being charged by the engine and you are using the battery to run the electric fan. And the fan is only needed during staging and not when you are running the 1/4 mile.
6. These cars are air-cooled and the role of the fan is very important. When you have the hood down and the car is travelling fast, you need a good system to keep the air flowing out of the engine compartment. The stock system does this job very well.
As you might guess, I'll be sticking with the stock cooling system since it hasn't been a problem for me.
> Jeez, why didn't we all think of this? Gain slight
> horsepower, no belt maintenance or replacement, faster delivery of engine heat > to the cabin...
> Good on ya'!
> On Thursday, September 4, 2014 10:09 AM,
> "Dr. Whiting theenginebuilder@... [2cylinderhondas]"
> > From a practical sense, studs would make the removal of the fan housing > > more difficult. Not much clearance to start with and there is no improvement > > in strength.
