Cylinder bore advice?
Scott Walters
Post by Scott Walters »
Hi all,
Thanks for the advice earlier recommending taking the side off and
looking at the oil pump on the '72 Coupe. Sure enough, the oil pump
had imploded. I don't know if the camshaft started eating itself
first and the metal clogged the oil pump, or if the oil pump imploded
and oil starved the camshaft. Probably the latter, I guess.
It looks like it might have 0.5mm oversized pistons in, but they're
badly scuffed from overheating. Measuring front to back, they're
74.49mm on one (R) 74.55mm on the other (L). Side to side, where they
aren't scuffed, they're 74.22 and 74.24.
Measuring the cylinders at the top, I get 74.52 side to side and 74.65
for the left and for the right,74.50 side to side and 74.42 front to
back. The bottom of the cylinders measure about the same but a bit
worse: L front to back is 74.72 and R front to back is 74.64.
I took the cylinders and pistons in to a machine shop today and they
suggested a 0.5mm overbore after a quick measure of the top. They got
slightly lower numbers than I did and I don't think they heard me when
I mentioned the pistons were maybe already oversized.
I don't have any experience with engine bores and pistons, so... questions:
Does this sound like this was over bored and had 0.5mm oversized pistons put in?
At this point, would it make sense to go for/stay with 0.5mm oversized
pistons or should I have it rebored for 1mm oversized pistons?
Thanks for any insights!
Regards,
-scott
Scott Walters
Re: Cylinder bore advice?
Oh, almost forgot l. The pistons do have "Honda" cast into one side
and "568B" on the other side.
-scott
On 9/9/13, Scott Walters wrote:
> Hi all,
> in?
> Regards,
> -scott
dm600z
Post by dm600z »
Hi Scott,
    Did you take your engine to an automotive machinist?  Or someone who regularly works on engines?
Go back and talk to the machinist and take your pistons.  If he is suggesting to go with 0.5 mm oversize,  go with it.
But do ask him why your measurement is different from his measurement?  What did you use .... micrometer or caliper?
     If the 0.5 mm doesn't work out,  why do you want to go with 1.0 mm?   These pistons were also offered in a 0.75 mm oversize.   After 1.0 mm,  then you have to have the cylinders resleeved which can be very expensive.
> Hi all,
> Thanks for the advice earlier recommending taking the side > off and > looking at the oil pump on the '72 Coupe. Sure enough, the oil > pump > had imploded. I don't know if the camshaft started eating > itself > first and the metal clogged the oil pump, or if the oil pump > imploded > and oil starved the camshaft. Probably the latter, I > guess.
> It looks like it might have 0.5mm oversized pistons in, but > they're > badly scuffed from overheating. Measuring front to back, > they're > 74.49mm on one (R) 74.55mm on the other (L). Side to side, where > they > aren't scuffed, they're 74.22 and 74.24.
> Measuring the
> cylinders at the top, I get 74.52 side to side and 74.65 > for the left and > for the right,74.50 side to side and 74.42 front to > back. The bottom of the > cylinders measure about the same but a bit > worse: L front to back is 74.72 > and R front to back is 74.64.
> oversized.
> I don't have any experience with engine bores and pistons, > so... questions:
> oversized pistons?
> Thanks for any
> insights!
> Regards,
> -scott
Scott Walters
Hi Dale,
Just the pistons and the cylinders, but yes. This outfit in town
rebuilds engines and does machine work.
I did. His response was, "This thing isn't super precise, but it
should clean up just fine."
As you can see, that didn't inspire huge amounts of confidence.
Between that and him wanting me to order and bring in the pistons
before he starts machining it, I'm balking.
Digital micrometer. He had a dial micrometer.
I'm tempted to pick up a bore gauge.
I don't know the ins and outs of different options. How would 0.5 not
work out? Would the machinist call me back and say that he needs to
go larger to get the scuffing out, or would it just be too
sloppy/loose of a fit against the pistons leading to more scuffing of
the skirt and blowby?
If I'm going to go with sloppy, it seems like the most logical thing
to do would be to stick 0.50 over pistons in and skip the re-boring
and let the minor scuffing work itself out on the piston rings.
That seems like the logical choice, but I don't see any of those
currently being sold online. I've found some Honda dealers that have
online parts finders with the N/Z 600 still listed, but very few parts
still in stock including no pistons of any size.
The pistons I do see for sale are care of O'Connor's at
http://honda600shop.com/parts.php?Category=N+%26+Z+600 and are only in
0.50 and 1.00 over.
Have any leads on 0.75 over pistons?
Thanks for your comments.
-scott
On 9/9/13,
goinhm@...
> Hi Scott,
> good luck,
> Hi all,
> questions:
> put in?
> Regards,
> -scott
Post by Lyle »
Hi Scott, I am a machinist so I like this stuff:)
The 600 motor is a motorcycle engine type, so I would recommend a bike engine machine shop. Search for a good shop in your area.
The best tool for measuring a bore is a dial bore gauge, but why buy one? Have a good shop measure it for you.
The only measurement you need is the largest bore size, usually at the top where the top rings dig into the bore, from the piston rocking in the bore.
The only measurement on a piston needed is 90 degrees to the piston pin on the lowest part of the skirt. Your pistons skirts are damaged so nothing left to measure.
Your measurements don't seem correct, a range of 74.42 to 74.72 that is about a 0.012" difference. The max bore size for a 0.50 piston is about 74.52mm or 2.9340". So if your measurements are correct then a 1.0 piston is needed.
If you go with a 75mm piston(1.00mm oversize).
Then the bore should be about 2.9530" and the piston 2.9510".
Buy the pistons first, they vary in size and must be matched to each bore and marked! The machinist will mic them at the skirts. Then bore the cylinders to within about (0.001") and "Perpendicular to the base". Hone to finish size to get 0.0015" to 0.0025" clearance. Check ring gap and you have a perfect job.
> Hi Dale,
and are only in
> 0.50 and 1.00 over.
> -scott
> On 9/9/13, goinhm@... wrote:
> > Hi Scott,
> > good luck,
> > Dale
> > Hi all,
> > questions:
> > put in?
> > Regards,
> > -scott
dm600z
Post by dm600z »
Hi Scott (and Lyle),
   Scott..... why not send your cylinder barrel to Lyle and let him do the machine work?  Then you know it will be done right.  And the barrel doesn't weight that much to ship.
   Some of the people on this post seem to sell pistons and rings.  And some have recommended Hastings
for their new rings.  Not sure who to recommend for the pistons (maybe Hastings can recommend a vendor or someone on here).
> The 600 motor is a
> a dial bore gauge, but why buy one? Have a good shop measure it for > you.
> The only measurement you need is the largest bore size, usually at the > top where the top rings dig into the bore, from the piston rocking in the > bore.
> The only measurement on a piston needed is 90 degrees to the piston > pin on the lowest part of the skirt. Your pistons skirts are damaged so > nothing left to measure.
> 74.42 to 74.72 that is about a 0.012" difference. The max bore size for a 0.50 > piston is about 74.52mm or 2.9340". So if your measurements are correct then a > 1.0 piston is needed.
> oversize).
> 2.9510".
> Buy the pistons first, they vary in size and must be matched to > each bore and marked! The machinist will mic them at the skirts. Then bore the > cylinders to within about (0.001") and "Perpendicular to the base". Hone to > finish size to get 0.0015" to 0.0025" clearance. Check ring gap and you have a > perfect job.
> Lyle
> --- In 2cylinderhondas@yahoogroups.com, Scott
> Walters wrote:
> > Hi Dale,
> > > But do ask him
> > I
> did. His response was, "This thing isn't super precise, but it > > should > clean up just fine."
> balking.
> caliper?
> micrometer.
> > > If the 0.5 mm doesn't work out, why do you want to go with 1.0 > mm?
> would 0.5 not
> he needs to
> too
> > sloppy/loose of a fit against the pistons leading to more scuffing > of > > the skirt and blowby?
> > > These pistons were
> > That seems like the
> > still in stock
> 0.50 and 1.00 over.
> pistons?
> -scott
> > > Hi Scott,
> > > Did
> or caliper?
> > > then you have to
> > good luck,
> > > Dale
> > > Hi all,
> > > Thanks for
> > > looking
> at the oil pump on the '72 Coupe. Sure enough, the oil pump > > > had > imploded. I don't know if the camshaft started eating itself
> > > It looks like it might have 0.5mm oversized pistons in, but > they're > > > badly scuffed from overheating. Measuring front to back, > they're > > > 74.49mm on one (R) 74.55mm on the other (L). Side to > side, where they > > > aren't scuffed, they're 74.22 and 74.24.
> > > Measuring the cylinders at the top, I get 74.52 side to side > and 74.65 > > > for the left and for the right,74.50 side to side and > 74.42 front to > > > back. The bottom of the cylinders measure about > the same but a bit > > > worse: L front to back is 74.72 and R front to > back is 74.64.
> > > I mentioned the
> > > I don't have
> questions:
> > > put in?
> Regards,
> > > -scott
scottwalters32
Post by scottwalters32 »
Hi Lyle and Dale,
Dale, not a bad thought!
Lyle, thank you for the thoughtful walkthrough. Are you interested in this
job?
I ordered 1mm over pistons but I suppose I could get 0.5mm over too and
keep one set on the shelf depending on how exact measurements play out.
Regards,
-scott
On 0,
goinhm@...
> some have recommended _Hastings_
http://www.hastingsmfg.com/?gclid=CMWAt ... Ogod4jsAmw) for their new rings. Not sure who to recommend for the
> good luck,
> left to measure.
> needed.
> perfect job.
> Lyle
> > Hi Dale,
and are only in
> > 0.50 and 1.00 over.
> > -scott
> > > Hi Scott,
> expensive.
> > > good luck,
> > > Dale
> > > Hi all,
> > > questions:
> pistons
> > > put in?
> > > Regards,
> > > -scott
Post by Lyle »
Hi Scott and Dale, I would like to help you, but I don't have the right machines or boring bars to bore an engine. I can do small Go-Kart engines that we race, but that's about it.
My website: Tru-Craft.com
Do a google search for motorcycle shops or automotive shops in your area. Then check out a few, a good shop will be clean and organized. They will take a couple measurements and let you know what you need. Motorcycle Race shops would be the best, they usually are more precise and are used to custom type machining.
You said the oil pump failed, how is your crank?
Must start with the crank, rod, bearings and move your way up.
My 2 cents.
, scott@... wrote:
> Hi Lyle and Dale,
> job?
> Regards,
> -scott
> > good luck,
> > Dale
> > left to measure.
> > needed.
> > perfect job.
> > Lyle
> > > Hi Dale,
and are only in
> > > 0.50 and 1.00 over.
> > > -scott
> > > On 9/9/13, goinhm@ wrote:
> > > > Hi Scott,
> > expensive.
> > > > good luck,
> > > > Dale
> > > > Hi all,
> > > > questions:
> > pistons
> > > > put in?
> > > > Regards,
> > > > -scott
Post by Lyle »
Here is a shop near me in Florida.
http://precisioncycleinc.com/cylinder_b ... eving.html
Use them as a guide.
Has to be a shop near you.
> My 2 cents.
> Lyle
, scott@ wrote:
> > Hi Lyle and Dale,
> > job?
> > Regards,
> > -scott
> > > good luck,
> > > Dale
> > > left to measure.
> > > needed.
> > > perfect job.
> > > Lyle
> > > > Hi Dale,
and are only in
> > > > 0.50 and 1.00 over.
> > > > -scott
> > > > > Hi Scott,
> > > expensive.
> > > > > good luck,
> > > > > Dale
> > > > > Hi all,
> > > > > questions:
> > > pistons
> > > > > put in?
> > > > > Regards,
> > > > > -scott
Scott Walters
Hi Lyle,
Neither the shop nor I are certain about whether we can get away with
0.5mm over pistons, and now I better understand why. I'm liking the
idea of ordering both sizes of piston and letting them sort it out,
but I'm still convinced this engine was already bored to 0.5mm over.
I was told it had a "full topend job 20k miles ago", measurements of
the sleeves are pretty close to 0.5mm over, and pistons are well
larger than spec. So I think whether it's still able to handle 0.5mm
over is a matter of wear and damage.
Crank is out of spec at the roller bearings at the ends. I feel a
tiny bit of play up and down where the crank arms connect but I don't
have any way to take the crank arms off to measure inside. Crank and
arms are one piece in Honda's parts diagrams, too. If I were smart,
I'd order a rebuilt engine and call this thing the parts engine.
Interestingly enough, someone claims to have crankshafts new:
http://www.bernardiparts.com/products/1 ... 8-190.aspx
I think I'm going to take my chances with a used one, though, if the
bearing journals are in spec.
The rollers themselves are described as "ROLLER (6X10)" or similar. I
don't see mechanical specs for them.
If I ordered something like
http://www.partzilla.com/parts/detail/k ... -Y006.html, any
guess as to whether it would fit and be correct?
Sorry for all of the questions but the temptation to try to pick your
brain is too great. I've spent days reading about stuff but that can
only general cases.
Cheers,
-scott
> Lyle
>> My 2 cents.
>> Lyle
>> --- In
, scott@ wrote:
>> > Hi Lyle and Dale,
>> > this
>> > job?
>> > Regards,
>> > -scott
>> > > do the
>> > > And
>> > > good luck,
>> > > Dale
>> > > bike
>> > > one?
>> > > top
>> > > bore.
>> > > pin on
>> > > nothing
>> > > left to measure.
>> > > is
>> > > about
>> > > piston is
>> > > needed.
>> > > bore
>> > > Hone to
>> > > you have a
>> > > perfect job.
>> > > Lyle
>> > > --- In
, Scott Walters
>> > > wrote:
>> > > > Hi Dale,
>> > > > > measurement?
>> > > > > mm?
>> > > > not
>> > > > to
>> > > > of
>> > > > thing
>> > > > re-boring
>> > > > have
>> > > > parts
and are only
>> > > > in
>> > > > 0.50 and 1.00 over.
>> > > > -scott
>> > > > > Hi Scott,
>> > > > > who
>> > > > > is
>> > > > > measurement?
>> > > > > mm?
>> > > > > mm,
>> > > expensive.
>> > > > > good luck,
>> > > > > Dale
>> > > > > Hi all,
>> > > > > and
>> > > > > pump
>> > > > > imploded
>> > > > > they're
>> > > > > they
>> > > > > 74.65
>> > > > > to
>> > > > > bit
>> > > > > they
>> > > > > got
>> > > > > when
>> > > > > questions:
>> > > pistons
>> > > > > put in?
>> > > > > oversized
>> > > > > Regards,
>> > > > > -scott
