Anyone have any pictures of the non-stock muffler installed? This is the muffler which has inlet and outlet on oppsing ends and requires modification to be installed.
Thanks!
Bob
Photos of non-stock muffler installed
bobs600honda
Re: Photos of non-stock muffler installed
Has anyone tried using a generator muffler to replace a stock muffler on a coupe?
I am having quite the challenge getting a muffler shop to do the required mods for a muffler - apparently there are no pictures available.
Thanks!
Bob
I sent you a pic of what I have..It was a rv generator that he shortened for me. I just had it taken off and put on a glasspack. But I am keeping the muffler in case I want to put it back on.
Sent from Samsung tablet
Reply to sender
Thanks!
Bob
Reply to sender
kingtrans2003
Try a snowmobile muffler. i did! Bought mine for a Kawasaki and with very little mod's to be able to use it.
On 31 Aug 2013 21:41:53 -0700 Has anyone tried using a generator muffler to replace a stock muffler on a > coupe?
> I
> am having quite the challenge getting a muffler shop to do the required mods > for a muffler - apparently there are no pictures available.
> Anyone have any pictures of the non-stock muffler installed? This is the > muffler which has inlet and outlet on oppsing ends and requires modification > to be installed.
> Thanks!
> Bob
One Weird Trick
Could add $1,000s to Your Social Security Checks! See if you Qualify…
newsmax.com
> I
> Thanks!
> Bob
One Weird Trick
newsmax.com
Robert James
Thanks!
On Saturday, August 31, 2013, tdthies1 wrote:
> I sent you a pic of what I have..It was a rv generator that he shortened for me. �I just had it taken off and put on a glasspack. � But I am keeping the muffler in case I want to put it back on.
> rjamesblues@...
> I am having quite the challenge getting a muffler shop to do the required mods for a muffler - apparently there are no pictures available.�
> Thanks!
> Bob
> Reply via web post
> Reply to sender
Robert James
Do you remember the model number / year of the snowmobile muffler?
thanks for any info.
Bob
Bob
On Sun, Sep 1, 2013 at 3:09 AM,
> Try a snowmobile muffler. i did! Bought mine for a Kawasaki and with very > little mod's to be able to�use it.
> On 31 Aug 2013 21:41:53 -0700 rjamesblues@...
> > writes:
> > Has anyone tried using a generator muffler to replace a stock muffler on a > > coupe?
> > I
> > am having quite the challenge getting a muffler shop to do the required mods > > for a muffler - apparently there are no pictures available.�
> > Anyone have any pictures of the non-stock muffler installed? This is the > > muffler which has inlet and outlet on oppsing ends and requires modification > > to be installed.
> > Thanks!
> > Bob
> One Weird Trick
> Could add $1,000s to Your Social Security Checks! See if you Qualify… > newsmax.com
Robert James
Sorry, please resend pic of modified rv generator muffler
On Sat, Aug 31, 2013 at 10:29 PM, tdthies1
> rjamesblues@...
> Thanks!
> Bob
> Reply via web post
> Reply to sender
kingtrans2003
i don't remember the model. it seems it was for one of the bigger cc one's.
i found it on e-bay and it was a nos and wasn't that expensive. also it was very quiet.
On Sun, 1 Sep 2013 16:47:14 -0700 Robert James Do you remember the model number / year of the snowmobile
> muffler?
> Bob
> kingtrans@...
> > Try a snowmobile muffler. i did! Bought mine for a Kawasaki and with > > very little mod's to be able to use it.
> > On 31 Aug 2013 21:41:53 -0700 > rjamesblues@...
> > > writes:
> > > Has anyone tried using a generator muffler to replace a stock muffler > > > on a coupe?
> > > I
> > > am having quite the challenge getting a muffler shop to do the required > > > mods for a muffler - apparently there are no pictures available.
> > > wrote:
> > > Anyone have any pictures of the non-stock muffler installed? This is > > > the muffler which has inlet and outlet on oppsing ends and requires > > > modification to be installed.
> > > Thanks!
> > > Bob
> > One Weird
> > Trick
> > newsmax.com
> muffler?
> Bob
> kingtrans@...
> > > writes:
> > > I
> > > Thanks!
> > > Bob
> > One Weird
> > Trick
> > newsmax.com
- Attachments
- us-13932.gif (3 KiB) Viewed 154 times
