I have the following cars and parts for sale at the honda 600 shop.
Coupe interior light lens, new
NOS oil filters
NOS air filter
NOS sedan vent window gaskets
Solid coupe dash with zero cracks
NOS engine gaskets
Cosmic mag wheels and new yokohama A008 tires
1971 AN600 Project car,
1972 AZ600 Coupe
1971 AN600 Truck
cars located in North Carolina
July 4th sale
Re: July 4th sale
got any good brake rotors ? looking for two , also do you know if the brake pad pin both had springs on them ? , my car has one spring per calipeer and im having a dragging problem on one side , i replaced brake hoses ,master cyl. ect with no change ....... thanks Dean M santa cruz ca .
On Sun, 7/7/13,
tmoc1990@...
Subject: [2cylinderhondas] July 4th sale
Date: Sunday, July 7, 2013, 5:20 AM
honda 600 shop.
NOS oil filters
NOS air filter
NOS engine gaskets
1972 AZ600 Coupe
1971 AN600 Truck
July 4th sale
Hi Dean;
There is only one spring on each caliper which should be on the lower of the two brake pad pins. From what you are saying the caliper may be binding on one or both of the caliper cylinder finger like springs. (the parts manual identifies them as Spring Yoke).
One of the pistons in the cylinder could be stuck too, in which case the caliper would have to be disassembled.
Re: July 4th sale
Thanks for the tip bill I'm gonna dig in today and check it out thanks dean Sent from my iPhone
On Jul 7, 2013, at 9:16 AM, "Bill" wrote:
Hi Dean;
One of
On Behalf Of
dean
m
Sunday, July 07, 2013 7:05 AM
Re: [2cylinderhondas] July
4th sale
On Sun, 7/7/13,
tmoc1990@...
Date:
AM
I
honda 600
shop.
NOS oil
filters
NOS air filter
Solid
NOS engine gaskets
Cosmic mag wheels
1972 AZ600
Coupe
1971 AN600 Truck
Carolina
Re: July 4th sale
Hey Dean - do you know of any other Honda 600 owners in Santa Cruz? I had a guy calling me continuously from a Restricted number at the end of June, he said he just bought a car and is living in Santa Cruz....
One spring per caliper. Did you rebuild both calipers? A stuck piston could cause a drag.
> honda 600 shop.
> NOS oil filters
> NOS air filter
> NOS engine gaskets
> 1972 AZ600 Coupe
> 1971 AN600 Truck
Re: July 4th sale
Did u replace the rubber brake hoses going to the calipers? Could be a collapsed hose that's letting fluid pass one direction but not the other.
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
> honda 600 shop.
> NOS oil filters
> NOS air filter
> NOS engine gaskets
> 1972 AZ600 Coupe
> 1971 AN600 Truck
Re: July 4th sale
Dont know anyone buy you around here with a honda , and ya new rebuilt calipeers and new brake hoses , I took my wheel off last night and noticed I forgot to put the springs back on the pad pins maybe thats the problem ? ill keep trying
On Mon, 7/8/13, feltonminicycle wrote:
Subject: [2cylinderhondas] Re: July 4th sale
Date: Monday, July 8, 2013, 1:07 AM
the
> honda 600 shop.
> NOS oil filters
> NOS air filter
> NOS engine gaskets
> 1972 AZ600 Coupe
> 1971 AN600 Truck
