Does anyone have one of the small throttle/choke cable holder that mounts onto the drivers side cam holder?
Its like 2" tall and would be right where the tach housing/cable is on a coupe.
There is a photo located here showing exactly what it looks like. I had one but somehow lost it during my engine rebuild.
condition doesn't matter as I'm gonna have it re-plated anyway.
Will buy outright or trade some re-plated engine bay parts or rubber bits
photo link below
Thankyou
Throttle and Choke cable holder wanted
Hi Eric;
You can make them. The round stock is 1/8 in dia, 81/2 inches long. The large opening is 1 in Dia, with the small opening 1/2 in Dia. The small end is pounded flat so it will bolt in place with the bolt (back upper shroud bolt) able to tighten it down without losing to many threads. Paint it using the gold and orange colors supplied by Eastwood Co.
http://www.eastwood.com/ Then, use some small vinyl tubing to cover the large end.
I can send a picture of the part if you like?
