Re: [anzhonda600owners] Are Honda 600 gas caps vented ?
Mark P Hatten
Post by Mark P Hatten »
Tom,
I drove to work this AM, took my gas cap off, still runs out of fuel...... and I completely removed the tiny filter before the needle and seat about a month ago.
I also put in a  4-7psi. Purolator micro fuel pump, it has 6psi. but not a lot volume.  Could be the 1/4" line is plugged, it's frustrating but I'll figure it out
Which jet did you replace?
Mark
www.mphspecialties.com
To: anzhonda600owners@yahoogroups.com From: tdthies1@...
Date: Mon, 11 Mar 2013 09:18:53 -0700 Subject: Re: [anzhonda600owners] Are Honda 600 gas caps vented ?
Mark I could not find a vent on mine but when I had my carb rebuilt it came with a different jet and the same thing was happening to me.  I change out my jet with one I had in a different carb and that solved the problem.  but your filter in the carb could be getting plugged again and that you will see when you check your jet.
hope this helps
Tom
> Mark P Hatten
> Monday, March 11, 2013 8:55 AM
> I seem to have a fuel starvation problem after driving on the highway for extended periods of 5-10 min or more, my gascap is NOT vented.
> I wonder if it should be ?
> Mark
