while pulling the suspension to be powder coated i noticed i had a front wheel bearing leaking very bad on my car. i have since pulled all 4 bearings and cleaned the knuckles up and am wanting to install all new bearings. I have sourced some koyo 6305 2RS with the help of old posts and google.
my question is this, with the original 1 sided sealed bearings you had to pack the center between the 2 bearding with grease, is this still necessary since both bearings are sealed now? or is it still needed for the spacer?
Thanks
Eric
