Flywheel/rotor pulling tool
I was wondering if anyone had a spare puller tool that they would like to sell? Or perhaps a neat trick to removing the flywheel? I believe the thread pitch is M23 x 1.5, can't find any bolts that size but it looks like an old toyota pickup has that size thread on the tie rods that could perhaps be modified.... thanks
Re: Flywheel/rotor pulling tool
My flywheel tool measures 24mm
Someone mentioned in the past that the hydraulic tensioner has the same size threads but I never double checked it. Metal on those is way too soft to use as a puller even if you had a spare one to cut to length.
Also... don't heat up the flywheel thinking it will come off. It's on a taper with no keyway and there are windings with plastic coating over the inside as it is also part of your alternator.
John Mills
Derek,
I have one I could sell
Thanks for the replies. Appears the thread is an M24 x 1.5. There are some metric hydraulic fittings in this size,and some odd car parts, it would appear that bolts are a rare thing. Some plugs are available on ebay that could perhaps be drilled and tapped for a pusher bolt ( http://www.ebay.com/itm/260929242662?ss ... 1968wt_954 ). I only need one, not 84 though!
, John Mills wrote:
> Derek,
> From: Derek
> To: 2cylinderhondas Sent: Sun, Jul 8, 2012 11:25 am
> Subject: [2cylinderhondas] Flywheel/rotor pulling tool
tommyjayallen
Derek,
The threaded end of a Volkswagen swing axle works perfectly for pulling flywheels. You can cut the end off and weld on a not or just use the whole axle. Your choice, but they are easy to come by and work great.
Tad
Derek To:
Sunday, July 8, 2012 3:53 PM Subject:
[2cylinderhondas] Re: Flywheel/rotor pulling tool
Tad
Derek To:
mailto:2cylinderhondas%40yahoogroups.com
, John Mills wrote:
> Derek,
> From: Derek
