Today was the day!!!!! my 1972 honda Z600 hit the streets for the first time since 1981, and boy was it a blast. After some hard labor I finally was able to take the "Green
Goblin" out onto the streets today. The car was hidden away since 1981 in an indoor storage area in Portland OR by the original owner and hasn't been out since. I bought it in april from the guy who found it there so technically I'm the 3rd owner but only the 2nd to ever see it run and drive.
Mark at MPH specialties in Portland helped get it running again after sitting for 31 years and then I finished it off. There's still lots to do but its on the road again.
Another Z600 is back on the road!!!
Here is a picture of her first bath
1972 honda Z600 rides again!!
Re: 1972 honda Z600 rides again!!
CONGRATS ERIC!!!! they are fun!!!!
> eric.geiger
> Saturday, July 07, 2012 10:34
> [2cylinderhondas] 1972 honda
> Z600 rides again!!
> Today was the day!!!!! my 1972 honda Z600 hit the streets for the first > time since 1981, and boy was it a blast. After some hard labor I finally was > able to take the "Green > Goblin" out onto the streets today. The car was > hidden away since 1981 in an indoor storage area in Portland OR by the > original owner and hasn't been out since. I bought it in april from the guy > who found it there so technically I'm the 3rd owner but only the 2nd to ever > see it run and drive.
> running again after sitting for 31 years and then I finished it off. There's > still lots to do but its on the road again.
> road!!!
Sadly yesterday was the only time for the foreseeable future that the green goblin will be on the street.
Upon looking for the cause of a rattle from a heat shield I found out the cooling fan assembly has come loose and ripped out all the Threads and also broke off the aluminum at the bottom of the block.
I have began the process of pulling the engine to send the guts along with a spare hea and block to be rebuilt.
It saddens me deeply as I won't be able to make the car show I really wanted to go to but in the long run the car will be much nicer, as I plan to media blast and re paint the entire subframe, exhaust, and anything else that's is a bit rusty. Ill also have all the nuts and bolts re played with zinc.
Hoping to maybe have it back on the road mid August.
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
> eric.geiger
> Saturday, July 07, 2012 10:34 PM
> [2cylinderhondas] 1972 honda Z600 rides again!!
> Goblin" out onto the streets today. The car was hidden away since 1981 in an indoor storage area in Portland OR by the original owner and hasn't been out since. I bought it in april from the guy who found it there so technically I'm the 3rd owner but only the > 2nd to ever see it run and drive.
Sorry about the OOPS on your little green goblin. But these little cars are tenacious and will go on. Mine had seperation anxiety from the owner that rebuilt her. But my little green is ok now. Had her in our centennial parade here in Prescott,Az.Look forward to future posts on your car.Laurie
> Eric
> Geiger
> Cc:
> Sunday, July 08, 2012 9:16 PM
> Re: [2cylinderhondas] 1972 honda
> Z600 rides again!!
> Sadly yesterday was the only time for the foreseeable future that the > green goblin will be on the street.
> Upon looking for the cause of a rattle from a heat shield I found > out the cooling fan assembly has come loose and ripped out all the Threads and > also broke off the aluminum at the bottom of the block.
> I have began the process of pulling the engine to send the guts along > with a spare hea and block to be rebuilt.
> It saddens me deeply as I won't be able to make the car show I really > wanted to go to but in the long run the car will be much nicer, as I plan to > media blast and re paint the entire subframe, exhaust, and anything else > that's is a bit rusty. Ill also have all the nuts and bolts re played with > zinc.
> Eric J. Geiger
> PRG Nocturne
> XXX-XXX-XXXX phone
> XXX-XXX-XXXX fax
> XXX-XXX-XXXX mobile
> egeiger@...
> www.prgnocturne.com
> On Jul 8, 2012, at 2:30 AM, "TOM THIES" tdthies1@...
> > > eric.geiger
> > > 2cylinderhondas@yahoogroups.com
> > > Sent:
> > > PM
> > > Z600 rides again!!
> > > Today was the day!!!!! my 1972 honda Z600 hit the streets for the first > > > time since 1981, and boy was it a blast. After some hard labor I finally > > > was able to take the "Green > > > Goblin" out onto the streets today. The > > > car was hidden away since 1981 in an indoor storage area in Portland OR by > > > the original owner and hasn't been out since. I bought it in april from > > > the guy who found it there so technically I'm the 3rd owner but only the > > > 2nd to ever see it run and drive.
> > > Portland helped get it running again after sitting for 31 years and then I > > > finished it off. There's still lots to do but its on the road > > > again.
> > > Here is a picture
> > > of her first bath
