Hello all, Mark at MPH Specialties currently has my Z600 and is trying to get it running for me. the only thing currently in his way is a clogged fuel line. its the tank outlet line that runs into the fuel filter. He has tried soaking it and spraying some carb cleaner and such down it and taken a wire and gotten through about 12" of it but he says its filled with a tar like substance.
Does anyone have any suggestions to clear the line.
Would a radiator shop who boils and seals tanks be any help??
if it can't be unclogged is the tank trash?
Thanks!!
Clogged fuel tank line help
Re: Clogged fuel tank line help
Lots more carb cleaner and 3 to 4 feet of small cable should clear the line. Putting the cable in a cordless drill at slow speed will help speed the process ~ you can also access the hard line near the tank as well as at the carb. .....and make sure the the short line into the tank is clear
good luck ....and don't give up
Thu, 5/3/12, eric.geiger
Subject: [2cylinderhondas] Clogged fuel tank line help
Date: Thursday, May 3, 2012, 8:24 PM
Thanks!!
From what I was told by mark it's the line from the tank to the pump.
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
> Hello all, Mark at MPH Specialties currently has my Z600 and is trying to get it running for me. the only thing currently in his way is a clogged fuel line. its the tank outlet line that runs into the fuel filter. He has tried soaking it and spraying some > carb cleaner and such down it and taken a wire and gotten through about 12" of it but he says its filled with a tar like substance.
> Thanks!!
That's a long line....with twists and turns.... old fuel will settle and solidify at the lowest points. The blockage is prolly along the rocker panel (least that's where the line runs on a Sedan). Chances are that 12" wire you used never reached the blockage.
Thu, 5/3/12, Eric Geiger
> From: Eric Geiger
> Subject: Re: [2cylinderhondas] Clogged fuel tank line help > To: "" > Date: Thursday, May 3, 2012, 10:23 PM
> Eric J. Geiger
> PRG Nocturne
> XXX-XXX-XXXX phone
> XXX-XXX-XXXX fax
> XXX-XXX-XXXX mobile
> egeiger@...
> www.prgnocturne.com
> On May 3, 2012, at 9:42 PM, "Dan Vann" catman_thirty3@...
> > --- On
> > > egeiger@...
> > > From: eric.geiger > > egeiger@...
> > > Subject: [2cylinderhondas] Clogged fuel tank line help > > > To:
> > > 2cylinderhondas@yahoogroups.com
> > > Thanks!!
the line from the fuel pump to the carb is clear. its just the line from the fuel pump into the tank
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
On May 4, 2012, at 7:05 AM, Dan Vann wrote:
> That's a long line....with twists and turns.... old fuel will settle and solidify at the lowest points. The blockage is prolly along the rocker panel (least that's where the line runs on a Sedan). Chances are that 12" > wire you used never reached the blockage.
> --- On
> egeiger@...
> > From: Eric Geiger > egeiger@...
> > To: " > 2cylinderhondas@yahoogroups.com
> > Eric J. Geiger
> > PRG Nocturne
> > XXX-XXX-XXXX phone
> > XXX-XXX-XXXX fax
> > XXX-XXX-XXXX mobile
> > egeiger@...
> > www.prgnocturne.com
> > On May 3, 2012, at 9:42 PM, "Dan Vann" > catman_thirty3@...
> > > wrote:
> > > Lots more carb cleaner and 3 to 4 feet of small cable should clear the line. Putting the cable in a cordless drill at slow speed will help speed the process ~ you can also access the hard line near the tank as well as at the carb. .....and make sure the > > > the short line into the tank is clear
> > > --- On
> > > > > egeiger@...
> > > wrote:
> > > > From: eric.geiger > > > egeiger@...
> > > > To:
> > > > Hello all, Mark at MPH Specialties currently has my Z600 and is trying to get it running for me. the only thing currently in his way is a clogged fuel line. its the tank outlet line that runs into the fuel filter. He has tried soaking it and spraying some > > > > carb cleaner and such down it and taken a wire and gotten through about 12" of it but he says its filled with a tar like substance.
> > > > Thanks!!
eric.geiger
The fuel line was able to be cleared with the help of a drill and a speedometer cable. THANKS EVERYONE!!
> Eric J. Geiger
> PRG Nocturne
> XXX-XXX-XXXX phone
> XXX-XXX-XXXX fax
> XXX-XXX-XXXX mobile
> egeiger@...
> --- On Thu, 5/3/12, Eric Geiger > wrote:
> From: Eric Geiger >
> To: ">" Date: Thursday, May 3, 2012, 10:23 PM
> Eric J. Geiger
> PRG Nocturne
> XXX-XXX-XXXX phone
> XXX-XXX-XXXX fax
> XXX-XXX-XXXX mobile
> egeiger@... www.prgnocturne.com On May 3, 2012, at 9:42 PM, "Dan Vann" > wrote:
> --- On Thu, 5/3/12, eric.geiger > wrote:
> From: eric.geiger Subject: [2cylinderhondas] Clogged fuel tank line help
> Thanks!!
Jesus Yepez
I have a 1971 Honda 600 and I'm want to buy the front windshield. Does anyone know where I could purchase one...Thanks.....
I have one. Where are u located?
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
