Fuel Pumps
Fuel Pumps
Post by feltonminicycle »
Has anyone besides me ever dismantled an electric fuel pump for n600?
Any easy way to get the small spring and 2 nylon washer back on without them takin' off across the room?
I have 10 dead fuel pumps.
Larybutt
Re: Fuel Pumps
Post by Larybutt »
Yes, I have two dead pumps!!!!
Re: Fuel Pumps
What?, so you took them apart and now they are dead?
> From: feltonminicycle
> To: 2cylinderhondas Sent: Mon, Jun 27, 2011 7:54 pm
> Subject: [2cylinderhondas] Fuel Pumps
Re: Fuel Pumps
Miles,
I have not had that problem.  Then, I have not had to go into the motor side of the unit, normally it is the bottom section that had to be replaced.
But I have a few that need new bottom section because the nipple is cracked or broken off.
> Monday, June 27, 2011 10:41
> [2cylinderhondas] Re: Fuel Pumps
> Larybutt wrote:
> > Yes, I have two
> dead pumps!!!!
> > -----Original
> Message-----
> 2cylinderhondas 2cylinderhondas@yahoogroups.com
> Pumps
> > Any easy way to
> get the small spring and 2 nylon washer back on without them takin' off across > the room?
Larybutt
Re: Fuel Pumps
Post by Larybutt »
Sorry about the confusion. I meant to say yes, I have dissembled a pump and now its useless!
The fuel pump on my TN360 is identical to the 600's
A disassembled pump came with my truck along with the leaky one installed. I attempted to disassemble and diagnose the leak. I gave up trying to repair it.
Lucky for me, I found a good used one and I have a driver again.
lostideas
Re: Fuel Pumps
Post by lostideas »
Are they the same as a Z pump? I took mine apart and re assembled correctly after a few tries.
Sent from my LG phone
>Steve
>From: feltonminicycle To: 2cylinderhondas Sent: Mon, Jun 27, 2011 10:41 pm
>Subject: [2cylinderhondas] Re: Fuel Pumps
>--- In
>> To: 2cylinderhondas > Sent: Mon, Jun 27, 2011 7:54 pm
>> Miles
