Hello All,
Should the Z600 be wired postive or negative ground?
Thanks!
-Ian
Z600: Postive or Negative Ground?
Pomeroy RH Ranch
Re: Z600: Postive or Negative Ground?
negative
but, where is the correct location??
Vance
Vance
On 1/3/2011 2:35 PM, ian_crosley wrote:
> Hello All,
> Thanks!
> -Ian
like most cars, the frame or car body is the place to attach the ground, with a bolt or screw and make sure that the surface is clean, bare metal.
Mon, 1/3/11, Pomeroy RH Ranch
> From: Pomeroy RH Ranch
> Subject: Re: [2cylinderhondas] Z600: Postive or Negative Ground?
> Date: Monday, January 3, 2011, 2:47 PM
> negative
> Vance
> > Hello All,
> > Thanks!
> > -Ian
Pomeroy RH Ranch
I have a few spots I can put it....but where is the factory-correct spot?
On 1/3/2011 3:56 PM, Alan Reed wrote:
> like most
> cars, the frame or car body is the place to attach > the ground, with a bolt or screw and make sure > that the surface is clean, bare metal.
> --- On
> > Subject: Re: [2cylinderhondas] Z600: Postive or > > Negative Ground?
> > negative
> > Vance
> > > Hello All,
> > > Should the Z600 be wired postive or > > > negative ground?
> > > Thanks!
> > > -Ian
