valve cover gasket
deantds
valve cover gasket
Post by deantds »
hi is there is a place to buy a new valve cover gasket for my az600 coupe 1972? my cover is tightend down tight and it is still leaking thanks for any help getting a new one. dean
Nutrition
Improve your career health. Click now to study nutrition!
http://thirdpartyoffers.netzero.net/TGL ... ASQwAAAAA=
Re: valve cover gasket
Post by feltonminicycle »
If you can't find a new coupe gasket, a sedan gasket will fit. Alternately you can add a shim washer under the head of the bolt for extra squish.
> Nutrition
agraygoat
Post by agraygoat »
I don't like doing it this way, but you can also get some RTV sealant from Kragen/Autozone-- go for the orange one as it is more high-temp. It's essentially a tube of rubber that can be used to seal up oil-pan leaks, valve cover leaks etc. if the gaskets are no longer available (sometimes to put them on the corners of some existing gaskets for extra protection during installation). Just put down a bead, put everything together, and wipe off the excess.
Don.
> Nutrition
dean m
Post by dean m »
An even better product is call "the right stuff"  good sealant for use with out gaskets.....
Thu, 12/3/09, agraygoat
> From: agraygoat
> Subject: [2cylinderhondas] Re: valve cover gasket
> Date: Thursday, December 3, 2009, 6:25 AM
> I don't like doing it this way, but you can also get some RTV sealant from Kragen/Autozone- - go for the orange one as it is more high-temp. It's essentially a tube of rubber that can be used to seal up oil-pan leaks, valve cover leaks etc. if the gaskets are no longer available (sometimes to put them on the corners of some existing gaskets for extra protection during installation) . Just put down a bead, put everything together, and wipe off the excess.
> Don.
> > ____________ _________ _________ _________ _________ _________ _
> > Nutrition
> http://thirdpartyof fers.netzero. net/TGL2241/ c?cp=aj_x- rDcP4wrGXcRsH0w1 AAAJ1FJewj2ooRpT cZqlpEOm2q_ AAYAAAAAAAAAAAAA AAAAAADNAAAAAAAA AAAAAAAAAAASQwAA AAA=
Cesar Cifuentes
Post by Cesar Cifuentes »
Does any one have an engine nd trans for a 71 N600?
dean m To:
Thu, December 3, 2009 9:48:11 AM Subject:
Re: [2cylinderhondas] Re: valve cover gasket
> From: agraygoat
> Don.
> > ____________ _________ _________ _________ _________ _________ _ > > Nutrition > > Improve your career health. Click now to study nutrition!
Kevin Keough
Post by Kevin Keough »
there is one on ebay now kevin
Fri, 12/4/09, Cesar Cifuentes
> From: Cesar Cifuentes
> Subject: Re: [2cylinderhondas] Re: valve cover gasket
> Date: Friday, December 4, 2009, 2:09 AM
> dean m
> --- On
> > From: agraygoat
> > Don.
> > > ____________ _________ _________ _________ _________ _________ _ > > > Nutrition > > > Improve your career health. Click now to study nutrition!
LCH Racing
Post by LCH Racing »
I have an spare engine and gearbox.  Unclear on the operability status, trans in NM. Also have a running complete  N600 in NM for sale.  Larry
> Cesar
> Cifuentes
> Thursday, December 03, 2009 7:09
> cover gasket
> dean m lt1ski@yahoo. com
> --- On
> Thu,
> 12/3/09, agraygoat
> > agraygoat
> > com
> > I don't like doing it this way, but you can also get some RTV > > sealant from Kragen/Autozone- - go for the orange one as it is more > > high-temp. It's essentially a tube of rubber that can be used to seal > > up oil-pan leaks, valve cover leaks etc. if the gaskets are no longer > > available (sometimes to put them on the corners of some existing > > gaskets for extra protection during installation) . Just put down a > > bead, put everything together, and wipe off the > > excess.
> > Don.
> > 2cylinderhondas@
> > yahoogroups. com
> > , "deantds"
> > gasket for my az600 coupe 1972? my cover is tightend down tight and it > > is still leaking thanks for any help getting a new one. dean
> > _________ _
> > > Nutrition
> > net/TGL2241/ c?cp=aj_x- rDcP4wrGXcRsH0w1 AAAJ1FJewj2ooRpT cZqlpEOm2q_ > > AAYAAAAAAAAAAAAA AAAAAADNAAAAAAAA AAAAAAAAAAASQwAA > > AAA=
agraygoat
Post by agraygoat »
Permatex makes "the Right Stuff" I believe, and also the orange RTV sealant that I was talking about. A lot of the mechanical shops use the orange high-temp stuff (it's called Copper something) around here. I've never personally used "the Right Stuff". You can walk into any autostore, and they should be able to point you into the right direction.
Don.
dean m
Post by dean m »
the copper and orange are two different things...... thanks dean
Fri, 12/4/09, agraygoat
> From: agraygoat
> Date: Friday, December 4, 2009, 7:01 AM
> Don.
Eddie Velasquez
Post by Eddie Velasquez »
does any one out there have a good brake master cyclinder? thanks . eddie @XXX-XXX-XXXX-
Sat, 12/5/09, Cesar Cifuentes
> Date: Saturday, December 5, 2009, 10:46 AM
> Would you like to sell them it me? Cesar
> LCH Racing
> Thu, December 3, 2009 8:11:54 PM
> > Cesar Cifuentes
> > Thursday, December 03, 2009 7:09 PM
> > dean m > lt1ski@yahoo. com
> > --- On
> > > From: agraygoat
> > > Don.
> > > > ____________ _________ _________ _________ _________ _________ _ > > > > Nutrition > > > > Improve your career health. Click now to study nutrition!
