Anyone know how to calculate cc's from piston/bore diameter?
Stock pistons are 74mm and we have 598.4cc
How many cc's would you get with 79mm pistons which have the same piston shaped top?
Stroke is 69.6mm
Math Wiz Needed !
twincarb600
Re: Math Wiz Needed !
680 cc or 42 cubic inches
> Stroke is 69.6mm
kuranhonda
I'm not a math wiz but I think this is the answer.
Bore x Stroke x number of cylinders equals cubic capacity.
The shape of the top of the piston will not alter the cc but will effect the compression ratio.
Mark.
Mark.
> Stroke is 69.6mm
using this calculator , I got 682.6 cc with the 79mm pistons
> feltonminicycle
> Saturday, October 10, 2009 3:43
> [2cylinderhondas] Math Wiz
> Needed !
> Stock
> Stroke is 69.6mm
